How much battery does Motorola connect use?
Not much? It never shows up my battery stats. If you use it for texting I would argue whatever it does use, it saves by not having the screen on.
Totally agree. It pings a simple sync like Google services apps do. It actually saves power if you use it because you can keep the screen on the phone off.
jenleasch12683
