gr8w8s Member Mar 18, 2019 7 0 0 Mar 18, 2019 #21 No, I don't have Nova. And if it is working on other people's phones, there is probably something goofy on mine that is causing it. Either an app or setting somewhere I haven't found yet. I'll keep digging. Thanks to all that responded!
gr8w8s Member Mar 18, 2019 7 0 0 Mar 18, 2019 #22 Found it!!!! I had the screensaver turned on. Once I turned that off, it works like I expect it to. Thanks to SpookDroid!!!
mustang7757 Admin Moderator Moderator Feb 6, 2017 97,316 13,322 113 Mar 19, 2019 #23 recDNA said: When you put the phone in your pocket does the proximity detector turn off the AOD? Click to expand... No
R recDNA Well-known member Jun 29, 2011 8,747 135 63 Mar 19, 2019 #24 mustang7757 said: No Click to expand... How about your Note9?
mustang7757 Admin Moderator Moderator Feb 6, 2017 97,316 13,322 113 Mar 19, 2019 #25 recDNA said: How about your Note9? Click to expand... It turns off.
R recDNA Well-known member Jun 29, 2011 8,747 135 63 Mar 19, 2019 #26 Probably will be fixed in an update
mustang7757 Admin Moderator Moderator Feb 6, 2017 97,316 13,322 113 Mar 19, 2019 #27 recDNA said: Probably will be fixed in an update Click to expand... Yeah I think so ..
N Notefan161 Well-known member Jan 9, 2019 810 11 18 Mar 19, 2019 #28 So far battery life been no different than without With Adaptive battery on its fine Having it off is what hurt my battery
A Adam Frix Well-known member Nov 29, 2015 1,095 0 0 Mar 19, 2019 #29 Notefan161 said: Anybody noticed much difference with it on or off? Click to expand... It's all about percent of battery life. On my S9+, more than I liked--so I turned it off. On my S10+, the battery is big enough that I can endure the draw. Nonetheless, it's a decent amount.
