[HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-Root!
Re: [HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-R
If you put on a wig there are some guy's around here who may take you up on this :-D
Sent from my PG86100 using Tapatalk
Which one u want me to wear?? Maryln Monroe wig or the Posh spice? :cool:
50/50. Wear the Marylin Monroe for half the day, then switch to Posh Spice.
<insidejoke>
But you also have to spend the entire day with the pink fairy wings guy.
EDIT: And his brightly colored lady friend.
</insidejoke>
<insidejoke>
</insidejoke>
LMFAO!
Ughhh... Keep getting title too long errors!
Oh... well slap me silly and call me susan. As you can see I DIDNT download it.. thats what I get for ASSuming. Thanks guys!
Here we go again! lol
Yes, this is to replace in its entirety the original image you have. You can unzip and flash it manually or you can place on SDcard and just reboot to hboot and it will flash it that way.
Edit: Using the hboot method I easily flashed right over CWM recovery with no issues.
Re: Updated TWRP 1.0.3
Basically, could not get recovery to flash in HBOOT.
Start at post #102 in this thread.
Is ti fixed now? If so I wont bother. If its still broken I will look.
EDIT: I looked.....
Seems to me he is not S-OFF. Check to make sure his phone says revolutionary at the top in HBOOT.
EDIT2: to test my theroy of S-ON you can have him try the manual way. If S is truly on then he will get a write permission error.
I got the revolutionary to recognize my phone. I entered beta key ... all good. But then it says something about lemons then it says "waiting for fastboot" and stays there nothing happens. My phone shows that it rebooted to the screen where it says htc shooter and I can choose reboot , reboot boatloader etc but revolutionary doesnt do anything from there ... any advice?
I have fastboot off in settings and degugging on
Do you have the drivers installed? http://downloads.unrevoked.com/HTCDriver3.0.0.007.exe
Reactions: HTCaesar
Thanks got s off but I couldnt download clockwork cause my pc had no internet only my phone. When revolutionary asked me to hit y/n to download I hit no. now I don't know how to get it on my phone. I downloaded it from the market but it says error while trying to run commands when I hit flash clockwork ... What else can I do ?
1234567890
Do not use clockwork... Use the steps outlined in the OP and you will have a much more stable experience.
You need to download http://dl.dropbox.com/u/30666591/RECOVERY.zip
You are downloading this via your phone correct?
After download mount your phone as a disk drive, move this file to your PC (do not leave it on your phone)
Extract it...
This will extract the "PG86IMG.zip" file.
Take PG86IMG.zip and place at the root of your sdcard on your phone
Now all you need to do is Turn your phone off and boot into HBOOT mode ( Vol Down+Power )
From there the phone will recognize the zip as an update zip and ask you if you would like to flash it.
Allow the flash of the recovery and then boot back up into your OS.
Remember to delete this file off off your phone after you succeed.
Reactions: HTCaesar
Next you need to perma-root.
I am re-posting this here because if you are doing this all through your phones browser it will be easier than going back to the 1st page over and over again.
PERMA-ROOT
For root you need to flash this .zip
Download here: http://dl.dropbox.com/u/30666591/su-2.3.6.3-efgh-signed.zip
In order to achieve root..
Download the su.zip and copy the zip file to the ROOT of your SDCARD.
Boot into Recovery
Choose "Install Zip"
Then "Choose Zip To Flash"
Then select the "su-2.3.6.3-efgh-signed.zip"
Once it completes, reboot and you now have ROOT access!
Thanks I'm about to try all that ...
Downloaded the su.zip, put on root on of sd went to hboot recovery it started installing but stopped and read:
E:Error in /tmp/sideload/package.zip
(status 0)
I downloaded the su.zip from my phone moved it to my pc then put it back on the root of my sd card. Should I have downloaded it from a pc ? My pc has no internet and I have to buy the sprint hotspot to use usb tether. Is this even the problem ?
Yeah I got recovery I installed ... just having trouble getting the su.zip file to install
myaff
