[HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-Root!
Re: [HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-R
I am running as an admin. I keep getting a debug error every time I run it.
You don't need sync. We just needed it for the drivers.
I figured out why those drivers didn't install. I already had the latest drivers installed already. so I uninstalled them then tried again. It's working now.
im having problems getting s off. so it recognizes my device but its saying my beta keys are invalid
Try copy and pasting the beta key. It has plagued many a people. Is it a 1 or an I or a l. Copy and paste will solve this for you.
the super user zip is saying failed signature. Ive downloaded many times and it still wont flash. anyone have the correct link to gain superuser
I just ran through all the steps and appears to have worked without a hitch.
Are you guys leaving fastboot off now that rooted? I always kept it off on my Evo because scared I wouldnt be able to get into Recovery is something went awry, but curious if there is another way if the phone temp bricks so I can fix it? I like the speed of boot up with it on.
Also if OP can update the SU zip on the OP. that would help alot of people out. I read through most of the thread and got on track quick, but not everyone reads fully so might mess people up.
Thanks guys!!!!
Thanks guys!!!!
Fast Boot = OFF.
If you do soft brick, pull battery then replace. Hold volume down then press power. This will get you hboot then from there you can select recovery.
Sorry for the rookie question, but need some assistance. I am new to Android and was able to get S-Off, install TWRP and make a back up. My issue is I have added the Superuser zip into the root of my sd-card and when I boot into recovery I can't find an option to "Install Zip". Can someone guide me on what to do. Appreciate the help. Thanks.
Are you sure you are in recovery? Install Zip is the first option when you boot into recovery.
Reactions: lfnsr
I believe so. Vol Down + Power at the same time - correct? Maybe I have it wrong. Let me know. Thanks for your help.
Sorry, found it. Duh. needed to go into recovery. That was my error. I am an idiot. :) Thanks.
Thanks again for the help. I know have Superuser. The process straight forward and easy to follow - as long as no user-error issues. Looking forward to trying out new ROMS.
Glad you got it working.
Reactions: lfnsr
Fast Boot = OFF.
Yes I know how to do this with fastboot off. Was just curious if there was a way with fastbook on if softbricked.
Figured there wasnt , but would ask.
I never messed with fastboot until I got this phone because it was on stock.
Anyway, thanks.
Anyway, thanks.
Yeah, thats the only way I know of.
I am not able to make any calls or send text msgs after doing this. I called sprint and they were not able to help me. What have u guys done
Nammna
