[HOW TO] Build A Theme-By SGBZ
C:\android-sdk-windows\tools\sign
I got the winsign in the proper folder layout now but it is still no letting me sign. If i right click on my edited apk it does not have the "resign apk" option like in the tutorial picture. I dont know what im doing wrong.
On the winsign link provided do i need any of the other files besides winsign? boot-tools?
sorry for being such a noob guys.
This will make it very easy for you.Take the attached zip,open it,extract the contents into the tools folder.Double click the autosign.bat file.Then all you do is
1 *hit enter
yes *type it,not just y,hit enter
2 *hit enter
yes *hit enter
3 *hit enter
yes *hit enter
7 *to exit
Everything should now be set up to sign.
I can't resist! I'm soooo excited...I had to give you one more Sneak Peek!
1 *hit enter
2 *hit enter
yes *hit enter
3 *hit enter
yes *hit enter
7 *to exit
Thanks SG, i will try tonight. And wow that halloween is too cool, i might have to switch up my hurricanes theme. :(
That should work.That's the way i set up all my pc's to sign.As long as you have java and android sdk set up then this will allow you to sign.If it doesn't after set up then try rebooting.
I would save the zip cause sometimes java likes to go nuts and you have to set it back up to sign.
Just a heads up that it worked and ive officially modded my first theme. thanks
Congrats,glad we got everything worked out.You should upload your theme and post it or pm me with a link to see it.:D
I feel like an idoit, that everyone has got this but i am at a lost haha, I have all the things downloaded and I am a graphic designer so photoshop is a breeze, but I dont know what to do NOW that i have all the files downloaded can we have a more detailed explanation on once you download them what to do to get started? thanks
I am cracking my head on how to do this but I am stuck at how to extract a rom. I downloaded to tools on my mac but I can't seem to figure out how to get the APKs out. please help.... maybe I'm just stupid.
I tried everything I could try and I'm still not getting it. Im so exhausted!! I wanna pull my brains out!!!!
after hours and hours of trying and almost pulling my hair, I think I got it! :)
no I don't got it. I need those picture samples displayed. :( I got all the way to extracting the apk's and modifying in photoshop, but I'm stuck after that on my mac. :(
Can you list out what you used to extract, along with steps, on the mac?
Also, can anybody else give some insight on how to finish the job on the mac?
Thanks!
k, im a fool i just noticed the hallowen theme has be up since the 30th. wow
Where's everybody's themes at? Here I was worried bout telling all my secrets but it seems like nobody wants to be a themer....:( Guess I'm one of a kind...
Take it as a compliment, some people just know they will never compete with Picasso so instead they sit back and enjoy his art ;) You are truly a Picasso of Android themes. Nobody will argue that.
Can the status bar up top be themed this way?
Yeap this is a basic guide of how to theme.It just takes a little diggin around to find the right files to edit.If i remember right the top bar is in the framework folder framework-res.apk not sure which file inside the apk i think check insside the drawable-hdpi folder.Thats all from memory so it might be in a different folder but it's in that apk.
i haven't figured out how to extract the images using a mac yet, so i have nothing to show :(
Have you checked youtube? There are probably some video tutorials on how to do the same thing on a mac. If you send me a mac I will figure it out and post it for you :P
well, i think i figured it out, i will give it a shot here soon. i just changed the "verizon wireless" to "phildo's droid x" on both stock lockscreen and the notification pulldown, and this included modifying the framework-res.apk :D
pmm09
