How to change Card view to Grid view Nexus 6 Marshmallow Help
EN4CER
20
Is there a way to switch between card view to grid view on a Nexus 6?
I was recently able to do this on my HTC M8 running Marshmallow, but just upgraded to the Nexus 6 and can't find a way.
Thanks for your help.
Brooky
No, the cards that are displayed when you press square button in the bottom right hand corner.
It shows stacked cards, I want to be able to display all the cards in a grid view.
Brooky
About your only option would be a custom ROM.... There may be an Xposed module, but a ROM would be the best solution.
Is there any launcher that can replicate it?
No, I'm afraid. A custom launcher can control your home screens and app drawer, no more than that. As LeoRex said a custom ROM is your best option.
Thanks for your explanation. Do you know of a good custom Rom that will achieve what I want?
Being a Nexus, there are dozens upon dozens of custom ROMs out there. I would suggest you head on over to XDA Developers and to to the Nexus 6 forums and start looking. I wish I could give you a definite answer, but it is more a question of personal taste and what you want... Hard for me to recommend anything.
boone
