How to clear cache partition from stock recovery (un-rooted phone)
This method posted by bikercr worked perfectly on my HTCd-626. Be prepared for the 3 button press after selecting recovery. Almost immediately there is the HTC logo with white background then blank. Press all 3 together and release. Then repeat. I got it on the 2nd repeat. Wiped the cache.
Just to clarify, you are saying this method works for you on the Verizon version HTC One?
I ask because once you scroll to recovery and hit the Power button the phone reboots immediately showing the HTC logo. There is no "Blank, dim screen".
Yes it worked perfectly on my stock HTCd-626. Prepare for the 3 button press once you select recovery. The HTC logo appears for 2s then blank. Press all 3 together and release. Repeat. I got it on the 3rd go.
Master zx
