[HOW-TO] Download/Install Honeycomb to Nook Color (SD card)
I just realized that nook color and nook tablet two different things, i have tablet, not color and i will return it to bn and buy color, i have to have full android on it.
I successfully burned the image to a Class-10, 16GB SD card. The image boots up successfully, HOWEVER< the touchscreen does not work, so I can't unlock it. Hmmmmmmm. Any ideas on how I can overcome this? For what its worth, I successfully imaged Cyanogen Mod 7 (CM7) and everything works flawlessly as it should. The Nook is relatively new and has absolutely no issues with the touch screen, so I know THAT can't be the issue. I am stumped......:confused:
"THREE things are definite; (1) Death, (2) Taxes, and (3) Hard Disk Failure. Fortunately, you'll only have to worry about two of them."
just a few simple questions.... once I have booted with the SD Card, if I want to install apps will it install to the SD Card? Also I see the following partitions... boot, disk2s2, disk2s3, and sdcard... I have used an 8GB card that now has 5+GB free space, how can i claim that free space for apps and other personal items?
Just waiting for the wife to get back from her trip with the nook.... So at this stage I have the SD Card writen and just need to get step 4 done.... this is done from the nook? where should i put those files?
Also I have several apk files that i would like to install, where should they go?
Sorry for the numerous questions, just fairly new to Android
:confused:
Running both Windows and Mac platforms so either platform for directions......
Thanks in advance!:D
:confused:
Honeycomb is broken, don't use it. Use ice cream sandwich or cm7.
Sent from my NookColor using Tapatalk 2 Beta-5
Ok folks, it's just not that easy. Followed instructions to root the nook with the clockwork for 4gb. I walked through instructions and had many issues consuming 10 hrs of my time between two computers...... Finally, got the honeycomb zip file loaded on the same card as clockwork utility. I started the install by pointing to the honeycomb zip file. It started to run and almost immediatly it came back with "installation aborted". Now What? I tried downloading a new copy of the zip file, no such luck. Now I've got a $200 door stop.
I know this is a stupid question but to get the android market do you download the downloads on your pc or your NC. Also what is adb tools folder
What are you trying to do?
Sent from the Center of My Mind
Have I done something wrong? My Nook says loading then has the word Android with a blinking prompt on the left side of the screen. Help? New to tablets.
I have downloaded WinImage under "disk" there is no Restore Virtual Image to Physical Drive. There is restore virtual hard disk image on Physical drive.
Same with me. I clicked on "Restore Virtual Hard Disk image on physical drive..." but it's not the same thing. I can't seem to get it to work. Help, anybody?
my nook color does not have a sd card slot that i can find so...I require assistance please
Really? On the corner that has the lanyard loop, on the back is a small cover held on with magnets. Under there. Google, nook color manual. And maybe RTFM.
Hey Guys i really need help when i download the image file it decompresses it for me on mac osx 10.6.8 and when i tried to copy the image file on the sd card i keep getting "no such file or directory" ! whats the problem ? ive tried three times and still cant get it. i mess up when downloading the files, because the directions say, "unzip" the image file but i didnt know how to do that, and if its opening it, ive already done that like ten million times.....im able to get the sd card unmounted but i just cant get past the part of loading it onto the sd card, this is my first time doing this, can anybody help please?
I was so fired up to get this working, but I have tried this over 5 times with the exact same results. I have rooted my Droid with no problem, so I have a bit of inclination, or at least can follow directions.
Anyway, I have an 8GB Class10 card I am using.
I connect to WinImage, select the honeycomb file, and follow the restore process.
I watch the dialog box, and it fills up in pink as it goes up to 100%. Once it hits 100%, it just closes - no Success or additional dialog.
I can see the files on the card, but when I put it into my Nook Color, it just boots normally.
HELP! I have downloaded the image multiple times, and don't see what else can be wrong.
Thanks in advance.
r3dpuk3
