[How to] Factory Restore (or Fix a Bricked Phone)
im using a pc
ok make sure you do the following
Reboot your computer
Do you know if you have the correct drivers, are you using 32bit or 64bit version of windows
if you have any antivirus running please disable it
Use USB ports in the back of the computer (if you already are change to another port in the back)
got it done and I am using 64
DUDE IT IS WORKING!!!
we are on factories and working!!!
Looks like you got it!!!
Thanks so MUCH!!
[HELP PLEASE] Epic 4g either bricked or idk?
I was trying to put the ViperRom on my epic, but i went to fast on everything and forgot to root im guessing and idk it just didnt work! so when i try to start my phone it comes to a screen with a computer and a little andriod person!
i have the stock rom and downloaded twice, i have Odin 1.0, 1.3, 1.7 and the correct PIT files. PLEASE help me i dont know what to do ! i need my phone asap thanks ALOT
[ i had tried putting gingerbread to ;; ]
you dont keep the baterry in?
well usually you do but if you are having problems it usually helps to leave the battery out and go into download mode... it allows for a more steady voltage
Those directions are for a fasinate but they are identical besides the methods of getting into download mode
i want to update to 2.2
Does anyone still have the official 2.2 download from the samsung website? i just got my phone and I miss the update. Can anyone help me out?
stopwatch
