How to Fix: Unfortunately, the process android.process.media has stopped
Try this before you do factory reset:
I kept getting this same error, "android.process.media has stopped..." and also "android.process.acore has stopped..." The message started after I unrooted. I was able to solve the issue by installing Jelly Bean 4.1 update. This is the link on how to do it:
Update Samsung Galaxy S3 Sprint L710 To Android 4.1.2 Jelly Bean VPBMD4 Firmware
I highly recommend backing up everything you hold dear before you root or unroot your phone. This update is what saved my phone as I didn't backup before unrooting. I couldn't make a call on my phone nor even install a backup app. I was about to restore factory update until I decided to try this first, and it worked. Make sure you are downloading an official Jelly Bean Stock update; the link on the instructions above works.
I have a Samsung Galaxy S3, Sprint. Hope this helps.
I have a Samsung Galaxy, the first one I believe which came out in 2012. My phone will not let me do a thing. I have done everything you could possibly imagine, factory reset, Settings --> Applications -->All--> Download Manager --> Clear Data/Cache. Not one thing worked. Help. :(
Omg i did that wrong sorry.. i have a lg optimus l9 phone i have tried hard factory reset tried to clear everything went into apps and tried to reset everything and disenabled and nothing works.. is there an app i can use to stop the error message.. its annoying
its same with me i can barely touch my phone for every 3 seconds its saying that unfortunately device monitor has been stopped PLZZZ helpp
i got a massage 'unfortunately ui has stop working' and i have power off my q3 tab.now i cant power on my tab,there is only showing anaroid and also i cnt power off my tab.please if you can help me to fix this problem
I just recently did a software update to my device, since my device was prompting me to. Then this error message would keep popping up after reboot and would slow down my device. It pops up about every 4 -5 seconds and won't give me a chance to barely do anything. PLEASE HELP!!!!!
Same problem plz help
I updated Galaxy2 (not rooted.....yet) via Kies from 2.3.5 to 4.1.2 JBean. No camera, alarm, music player, or gallery and had the annoying process media error message almost constantly.
Tried removing SD card, disabling account syncs and cleared every cache there is with no change.
Disabled DRM protected content and disable Media storage apps, using settings> application manager>all.
This basically stops any access to any media (music, ring tones, sd card ,photos, etc).
So I reluctantly did a factory reset not expecting it to work...but it did
Worth a try.
:)This is what worked for my Nook with Androidfornook sd card. Finally!!! Thank you so much for this much needed solution!!! !::):D;):-*
Thanks for the answer
Q. How to Fix: Unfortunately, the process android.process.media has stopped ?
A. To solve gallery problem, just go to Settings-Apps-All- find Media Storage- then click Enable..
Re: How to Fix: Unfortunately, the process com.android.phone has stopped
I get message tittled 'Unfortunately, the process com.android.phone has stopped' from my TV mobile phone when i turned on. since getting this message i cannot make a call from TVC phone. please assist how to rectify this problem
Regards,
Ngowi
add simple one line code in your AndroidManifest.xml file
< application
android:allowBackup="true"
**android:largeHeap="true"**
android:icon="@drawable/ic_launcher"
android:label="@string/app_name"
android:theme="@style/Apptheme"
I have the same problem :(
That message comes and my tablet shuts down automatically! I can't open my Music, Google Play Music or Camera!
One of my friend suggested Clean Master Cleaner to delete the junk files!
This seems to be working for now. Thank you for the link. I hate to say it but after paying this much for a phone and having as many issues with it as I'm having, I will be going back to iphone with my next upgrade. This is out of control.
tryhomematch
