[How to] Flash Full package DL09 and Stock DI01 via Odin
After flashing via ODIN I am unable to mount my phone's SD card via USB on both my Win7 PC and my MBP.
Has anyone else had this problem?
yes , try reflashing again, some people got it to work right away, i had to flash it a third time, Adrynalyne is trying to figure out the problem and a fix for it but for now its kind of random when it happens
Reactions: jbr05ki
Hey all, I flashed DL09 through Odin last night with no issues. The GPS fix is great. I went to try and re-root this morning using one click, and it will not recognize my phone as connected. I have all the drivers loaded, and had it rooted before I flashed the DL09 last night. Anyone else having similar issues?
I flashed DL09, rerooted, and want to flash a rom in CWM, but each time I try to backup my current rom, it fails. any ideas? should I just go ahead and flash anyways?
sometimes you have to reflash it..
other options are , with your phone plugged in and in debug restart the phone while plugged
or you could
flash back to DI01 and do the OTA to DL09 hopefully that will fix it
but reflashing DL09 worked for me
Reactions: 10001110101
I am tying to rename the crapwares using Root Explorer but keep getting error "cannot be renamed because the file system is read-only." The phone is rooted. Is anyone else getting the same error?
At the top of root explorer is a button says mount r/w hit that and try again
Sent from my SCH-I500 using Tapatalk
i did this and flashed it correctly through odin and now my phone wont mount to my computer. What do i do to fix this??
I have tried it 3 times already with no luck. It also wont root with Z4root. what should i do? what would be the best way for me to get DI09. should i flash it back to DI01 first? i heard the all-in-one package can cause this as well and its permanent. Or should i just keep flashing the same one over and over again and hope for the best?
Try DI01 and do the OTA....after ota put it in debug plug in and wait a couple mins and try
criteriascenario
