[How to] Flash Full package DL09 and Stock DI01 via Odin
ok, so now if i flash this file like i just did with DL09 through odin then i should be able to do the OTA upgrade no problem? and hopefully everything should be fine?
Yeah same way , it will leave you stock out of the box DI01 and then to the OTA
as far as everything being fixed i cant promise that. people also have reported having trouble with USB support with the OTA , so its very random, the OTA actually fixed mine
It figures...Mmy wife and I both have Fascinates and I was tired of waiting for the OTA. I flashed mine last night with DL09 and I just check with hers and it says the OTA is available now. I guess I will be able to compare the 2 in about 15 minutes. It says the update is only 16mb. I'll see if I can find any differences.
Yep, completely identical. The OTA seems to be the same as the file I flashed. I also checked for updates on my "updated" phone and it says nothing available.
Reactions: DroidXcon
sikhanegi
