How to get notified of voicemail received when phone was off, or Airplane Mode? Galaxy S7 Edge.
here is what i get when i press the phone button https://www.cjoint.com/c/JBxtzCScGjH
here is what i get when pressin three dot https://www.cjoint.com/c/JBxtBdsObvH
and when of those option when i press parametre https://www.cjoint.com/c/JBxtCs8XNAH
how to swith language to english it will help.
i cannot find storage of phone app nor its notification
I still have the problem, the phone app does not appear in the parameter notification...
is it easy to reset the phone can i do this since it come from korea?
im willing to open a zoom video app and send a check to anyone who would get me to see those voicemail notifications.
i just tested again and the notifications are received when my sim card is in my old phone on airplane mode to the prob is in my phone settings.
when i click Power + Home + Volume Moins,
i get this https://www.casimages.com/i/200304050220879178.jpg.html
should i try a reinitialisation of factory parameter? will that work or bring me more problemes since the phone is originally from korea?
Usually you shouldn't get voicemail until airplane turns back on ,it needs data , what phone was your old phone?
my old phone was a lg
I m not sure to understand what you say
when airplane mode is on there is no data. so i should get notifications when i turn air plane mode off ( receiving data)
ok...so what can i try to solve this?
i seem to have a soft different from the pic you showed
you talk about cache. the cache of what exactly?
Clear cache , I was referring to is the apps cache ,data, force close ..only if it's not giving notification, but you say it is when not in airplane mode .
in device maintenance i clicked on storage and clared like this
<a href='https://www.casimages.com/i/200323104658150676.jpg.html' target='_blank' title='Mon image'><img src='https://nsa40.casimages.com/img/2020/03/23/200323104658150676.jpg' border='0' alt='Mon image' /></a>
just to be clear on airplaine mode.
when airplaine mode is off it means that data is on and when like this, if im in the bathroom and my phone rings in kitchen and someone leaves a message , i will see a voicemail notification when i come back from bathroom so that is ok but when i go to sleep i put airplain mode on to redue emf exposition. if someone leaves a voicemail during this time and that i turn airplane mode off when i wake up, i do not receive any notification even if someone has left a voice mail. that is on my edge 7
i tested with old d850 lg phone and with the same coditions, he will show me a notification wich tells me the provider is set ok and does its job.
when i click apps show system app, i see this ,4 phone app. <a href='https://www.casimages.com/i/200323104656783700.jpg.html' target='_blank' title='Mon image'><img src='https://nsa40.casimages.com/img/2020/03/23/200323104656783700.jpg' border='0' alt='Mon image' /></a>
i see force stop is this what you talk about ? how would force stop help ?
Yes force stop is there right corner but go in storage there and clear data,cache then force close
hi i really do not understand your explanation hahaha
you suggest for a solution to force stop but you say it will not help.
can you explain? .
i notice you put a few words in you recent answers . would there be a time more suitable for you to help me cause on one hand im french so it helps if the explanations are more exaustive and on the other i feel confused about you suggestion and how it will contribute to solve the prob.
sory for misspelling some words,
cordially
eric
can you explain? .
cordially
eric
That was early on in the beginning, so what I want to say is airplane mode you WONT get notifications or calls ...When it's NOT in Airplane Mode You will
ok but from what i understand, when i am in airplaine mode or when the phone is simply off and someone leaves a voice mail, when i switch my phone to airplaine mode off, the phone should tell me : heywhile you were offline someone left you voicemail so check it out!
my ok phone does show me these "stored voicemail notification" and my edge 7 does not. it is supposed to let me know as i turn my phone on that i received a voicemail while my phone was off. isn't it ?
Because in airplane mode it has no data or signal
yeah of course i dont expect to receive a notification if my phone is off or airplaine mode is on... what i expect from it is that when i turn it on, it lets me know that i received a voicemail while i was off.
No it wont , I tried this
well why does my old phone can do it why before on my edge it was able to do it
on top of this it would not make sense cause all people reconnecting to data would not know that they received a voce mail?
I have newer Android phones so maybe something Google changed through Android updates on newer phones
Algarañaz
