How to go back To stock
Status
Not open for further replies.
The links appear to be broken, getting a 404 error. Anyone have a mirror?
Please help me
i installed voodoo lag fix and everything went fine but i tried to uninstall it and its not working
I made the folder called disable_lagfix
restarted it
and its been over an hour and nothing has happened what should i do !!!!!!:confused::confused::confused:
PLease help me i dont want to brick my phone!:(:(
I did this and I get a network error in the Market and Google Voice doesnt open. It also looks like Gmail isnt pushing emails. I thought this was suppose to be stock? Anyone have any ideas?
Sounds like a bad flash, i would try again
Need help...Do I hold the volume down button and plug in the USB cable after I hit power off the phone on the screen? It's not working or I'm doing something wrong!! Probably the latter...
Thanks
I think I did it correctly. Now I have a yellow triangle that says downloading and at the bottom it says do not turn off target. It's just sitting there. Did I do something wrong?
I figured it out. I forget to install odin. What a dummy!!!
Thanks for your help. This is the best forum!!
Peace
here guys this is a more detailed guide, there is both DI01 stock and the DL09 (leaked) stock
http://forum.androidcentral.com/fas...full-package-dl09-stock-di01-via-odin-12.html
both use the same directions so the files are interchangable
@JayHawk,,, yes using oding will wipe everything and leave you out of the box stock
but all purchased apps can be retrieved from market once you sign in again after this is done,
to save apps
you can also use titanium backup if you are rooted
or
Mybackup pro ( so ive heard, i havent tried it)
Status
ruhidubey017
