How To Guide Too Install Android 4.0.4 update.zip
Re: Manually install ICS direction
Right on lemme know asap plz
Sent from my LG-LS840 using Android Central Forums
You guys are the greats I just got the update to work!!!!!!!!!!!!
Any way to reboot into recovery without adb?
Sent from my EVO using Tapatalk 2
When it shows an arrow coming out of a box and an android dude is it supposed to hang on that screen?
Ok I fixed it, thanks everyone.
there are free apps in market that you can download and should do the trick
- - - Updated - - -
nope, redoing the guide too help everyone better
- - - Updated - - -
The button combo for stock recovery is volume up and power
Sent from my LG-LS840 using Tapatalk 2
Working good.
That combo doesn't work I've tried like 10 times volume down and power is factory reset volume up and power does nothing
the only way i knew too get into stock recovery was adb reboot recovery
lulz how did u get it to work? im stuck where you were! just the arrow coming out of the arrow coming out of the box and no update/status bar...
brucestark2741
