How To Guide Too Install Android 4.0.4 update.zip
Re: Manually install ICS direction
Hold the power button until you get the "phone options" menu and then choose "power off."
With the phone powered off, while pressing and holding the voume up and down buttons at the same time, press and hold the power button until the phone starts and then release all three buttons.
You're now in the "Boot Mode Selection Menu"
- Press the volume "down" button once to move the selection to "recovery"
- Press the volume up button once to select "recovery"
The phone will now boot into recovery mode. You should first see the Moto logo followed by a picture of a droid.
these are directions from a moto device but its the same on the viper...with the phone ON....jus hold power and choose power off and immediatly press vol+&vol-&power button at the same time...wait for it to power up and release the power button whill still holding vol+&vol-
Press and hold the voume up and down buttons at the same time.
Your now in the recovery menu.
IS there a progress bar on something? Just setting here for maybe 5 minutes...
renamed the file update.zip put it in the root of the sdcard and then rebooted into recovery. selected the install update.zip option and now its sitting on the screen with the box and the android. I was wondering if there's a progress bar or do we just wait?
EDIT: figured it out....home button is the select button....
i think ppl are gettin confused with what the home and menu button functions are, so it seems..."home" button is the select function...and the volume up and down is for scrolling
just press menu key to go back to menu and use home button to select, and you can thank tommyjoe for that little ditty
thats odd man. i redid the thread and put new directions on it. I would try doing it again. I made the guide a little bit easier
Yea im used to phones were power button is usually the select button in recovery. To tommyjoesanders i figured it out...edited my post.
lulz how did u get it to work? im stuck where you were! just the arrow coming out of the arrow coming out of the box and no update/status bar...
I had named the file update.zip.zip using my phone . I re downloaded it on my pc and renamed it update.zip and put in on my sd card.
cmd tells me "c:\" is not recognized as an internal or external command, program or batch file... HELP!!!!!( thanks by the way to everyone working on this)
Did you ever get it to work? I'm having the same problem.
People unfamiliar with cmd are probably having a little trouble. Use the command "cd c:\adb" to change directories to the adb folder.
To get into recovery once you get to the factory reset screen and it asks you to confirm,do that and as soon as you see the next screen press the menu button. Next to the home button. If i remember right that's it.
When I get to the c:\abd directory and enter the command it says daemon starting something or another but then eventually concludes to "Device not found"
?? I'm in the debug mode.
try this command too make sure your phone is connected
adb devices
if you dont get anything back. unplug the usb from the pc and plug into another usb port and redo adb reboot recovery. hope that helps
Thanks for the uploading and help man! I'm on ICS as we speak
ok so my issue is that i deleted a lot of the sprint apps and the "checking current system" fails because its looking for sprintid.apk and i removed it >.< does anyone have these sprint apps from gingerbread?
pvk
