How to keep app open?
  • Start date Start date
If it doesn't happen in Safe Mode, then that suggests that something you installed is causing the apps to get killed. Do you have any "RAM booster" or "phone cleaner" apps installed? Also any 3rd party file manager apps?
Re: App close themselves when I lock my phone.
B.diddy told me to try safe mode it work but after switching back the problem persist.
Try turning developer option off completely that way we know no issues there, then if still issue and you tried safe mode and didn't happen, most likely a app or application you downloaded.
Thank you B.Diddy everything working fine now. The app that was causing the problem was google translate app.
Great! Although it's odd that Google Translate would do that.:confused:
changan9175
