[How To][Links] ROMs/Themes and Kernels ~# Updated 3/20/11 #~
Status
Not open for further replies.
does anyone have any info to how smooth the EB01 Bloody Myst v2 - kenesis theme is im loving the reds but im not seeing anyone talking about it at all ive had themes get all jacked on me so i get hesitant help would b great thanks to all and any
Did you read the theme developer's OP? Click on the developer's name next to the theme name and a new window will open taking you to the theme's OP. That's probably the best source for info on each of the themes.
Reactions: T3CH9ICIAN
I wish I could offer more information. I only ran this theme for a couple of days back in February. I had no issues. There were some issues initially with the apps - but that was corrected by the developer.
kenesis has not provided any updates for that theme in some time (Early Feb).
yea ive read them and i was just looking for alil more info was all thanks another question is i love the boot up light flashing honeycombs hexagons on the NitroHoneyComb 2.0 theme can that b made into a live wallpaper ? to me that would b sick id love it and battery consumption wouldnt matter much to me on that haha
Would you like to test a beta version? - I am getting ready to compile my first apk.
Edit: Done... link removed
sure ill give it a try what all goes along with testing something ? what am i looking for or reporting ? apk ? android package kernel ? what does it involve to get it on my phone simple flash method like a theme ?
ive got it dl on to pc does it just get moved on to sd card like a theme then from there how do i apply it to my phone ?
Copy to your sdcard and install like you would any other application. Don't flash. You should install via your file manager (Root Explorer or just My Files) Click on the file name "Purplecomb-signed.apk" and the system should ask if you want to install - you do.
Report back any errors you get..
If you get a good install report back any graphical hiccups or other issues.
the wallpaper name is Electric Purple Comb the small box image next to it on the left is a droid with custom lwp underneath but only a bright white screen when applied or any setting changes that are there
Reactions: JaeKar99
Yep - I was afraid of that - you and I just got our first taste of a beta version.. Sorry man. I will have to pull the link down and try again..
I really appreciate your time and investment. I will definitely knock again when I get this up and running.
To un-install go to your task manager and select package and the wallpaper will be there... uninstall and you will have to reset to the wallpaper you had previously.
no i wasn't i just had a standard wallpaper but after it came up white i changed to a diffrent live paper and its worked my grassy day to night works as well as many others hey im a very patient person id love to b one of the first sunning a paper like that its an amazing image i love watching my boot up thank u for the work ur putting in i love this forum nothing like it
Reactions: JaeKar99
Ready to try some Livewallpaper again? - I got the issues resolved with the white screen (hexidecimal off) - Any how here is the Electric Purple Honeycomb version 3 - Link
Installs the same as the first version. When you set up the speed; I had good images above 45 frames per second... the size - Large.
Welcome to try it out. Please offer feedback..
Status
Kenny Fluent
