How-to: Fix "Your device has failed verification and may not work properly" message on boot error
  • Thread starter Thread starter Ry
  • Start date Start date
Ry
Moderator Captain
Trusted Member
Nov 16, 2010
17,654
215
I rarely reboot my device so I don't know when this error started happening. Some say it started with the first OS update (September security patch?) for Moto Z Droid/Moto Z Force Droid. For all I know, it could have been there from day one. I didn't think anything of it because I know I didn't modify anything - my bootloader remained locked (oem_locked appears on the fastboot screen).
I noticed that this was causing an issue when Android Pay stopped working after it was updated to no longer work on devices where the bootloader was unlocked. Getting updated to Nougat did not resolve the issue. We got a discussion going on in the Lenovo support forums and after some time, it was suggested that we repair the OS install and for the Droid models, a customer-facing tool is available!
https://forums.lenovo.com/t5/Moto-Z...rification-and-may-not-work/m-p/3495375#M2268
Use the Verizon Software Update Assistant to repair the OS
Prerequisites: Windows or OSX, USB Type A to USB Type C cable (you could probably do C to C if you had a newer Macbook)
  1. Download and install the Software Update Assistant
    Windows: https://forums.androidcentral.com/e...com%2Fverizonsoftwareupdatewin&token=OXSxgn6n
    Mac: https://forums.androidcentral.com/e...com%2Fverizonsoftwareupdatemac&token=fjvGroHv
  2. Open Software Update Assistant
  3. Connect your Moto Z Droid or Moto Z Force Droid to the computer.
  4. Swipe down the Notification Shade and select the "Software Installation" option.
  5. Wait for the Software Update Assistant to detect your phone.
  6. When your phone is detected, click Restore.
  7. You'll be prompted to choose Erase or Keep Data.
  8. The Software Update Assistant will download the OS image, then install it to the phone. The phone will reboot to the Fastboot menu. Do not disconnect the phone.
  9. When complete, the phone will reboot and you can disconnect it from the computer.
If this is happening on a GSM unlocked model, I'm not sure if there's a application available.
Re: How-to: Fix "Your device has failed verification and may not work properly" message on boot erro
You are a beneficent genius!
This problem is all over the web and this is the only intelligent and useful response. It fixed the problem for me.
Thanks!!
Thanks!!
Let's make this thread the number one search result. lol.
Well..... What does one do when the software assistant states the software is up to date with no option given to force a download? irritating....
    Windows: https://forums.androidcentral.com/e...com%2Fverizonsoftwareupdatewin&token=wDa-zqMg
    Mac: https://forums.androidcentral.com/e...com%2Fverizonsoftwareupdatemac&token=hgZmh3EB
Does this solutions also work for the same problem on MOTO G5 or is solely for the MOTO Z?
does anyone know of a fix if I don't have access to a computer? after trying to install a custom recovery I now get secure booting error message 1003 when trying to get into recovery mode. other than that my phone works fine. just no recovery anymore. LG Transpyre vs810pp in 5.1.1.
can I do a OTA update? will that repair my recovery partition?pls msg here or email me at [e-mail removed by moderator]
email is best.
email is best.
This is the Moto Z Force forum.
uOttawaGrad_22
