[How To][Links] ROMs/Themes and Kernels ~# Updated 3/20/11 #~
Status
Not open for further replies.
SUCESS!!!! ahhhh i cant thank you enough...you guys really are the best on here you have no idea.!! i was really starting to get scared and i truly appreciate you hanging in there with a noobie like me...thank you thank you!
Anytime. Glad it turned out well.. Pleasure to be of help.. Almost everyone here has been down this road..
More than one time...
Once you get what you want settled on your phone; back the rom up on cwm.
Have a great evening.
one last question lol....i backed everything up on titanium...how would i go about getting that back? or is it better to just manually go through and download all the apps
Download and install Ti backup
Make sure you have selected on phone Settings>Applications (check unknown souces) that will let you install via Ti backup.. also while you are there under Development check USB Debugging..
Then go to Ti Backup, menu> Batch restore missing aps with data.. that will put you back with all your apps.
Reactions: whussain0
can you run superclean dj05 on djl30?
If you are referring to using a DJ05 theme on a DL30 kernel/ROM - no you cannot.. bad things happen.
If you are talking about running a DJ05 ROM on a DL30 Kernel - Not a good idea - bad things happen..
DJ05 and DL09 have some (few) interchangeable properties but (radio and some themes with the theme fix for DJ05 themes on DL09)..
As soon as you start to mix outside of the family (especially 2.2) it all goes bad - FAST.
I guess the short answer is "no".
How do i know which themes will work with which roms and do i need to download a kernel to run a theme? im running RubicS posted at the beginning of this thread and want to run gingerbead theme...will that work together?
you are looking for the build number, ie. dl09, dl30, dj05. match the build. it will say in the link.
thatdudebutch has posted a update for SuperDark. You can get v1.5 via his original post at XDA here. Thanks for managing this list JaeKar it has definitely come in handy!
Reactions: JaeKar99
Admin and Moderators are cleaning up the threads and consolidating.
I will continue to update.
Just thought I'd through it out there that I think should be stickied in some way or form. Not complaining or saying that I know best, just putting in my .02. Thanks again for all the hard work JaeKar
There is the option to subscribe to this thread. Under "Thread Tools" on the upper right hand side - top of the frame on the first post...
That is how I keep track of it. It is an option.
Adrynalyne has included a voodoo kernel in his Superclean 2.1 ROM of EB01.. It can be found here.
All voodoo precautions should be exercised with this kernel.. do not flash a nonvoodoo kernel until the lagfix is disabled.. I have not tried this kernel. However I trust Adrynalyne's work and have been using his nonvoodoo version of this ROM for a couple days without issue.
EDIT: I just discovered voodoo EB01 kernel from jt1134 - link..
Happy Flashing..
Just a heads up, I just flashed Droidxcons debloated EB01. Which looks to be just about the same set up as DL30 as far as bloat goes and also looks to be deodexed. I took a look at system through root manager and it looks like adrenalyne took the time to deodex in addition to removing the bloat. So this should also work with custom themes without a problem, I am currently using midnight theme with theme fix hack and it works great, only missing AOSP lockscreen. Which is the price you pay for Theme hack.
Soon there will be a whole post full of themes and just a couple of ROMS. I have my mind set on Black Mod Enhanced.. Worked really well with my phone and an undervolted kernel.. I could get almost 60 hours between charges... on a moderate use day..
I'm also waiting on Blackmod Enhanced. Loved the way it looked.
EDIT- Now I'm going to have a tough choice if blackmod comes out for EB01. Loaded up blackish storm and it is sweeeeet
Love that theme!!... Ran Blackish on SC 2.0 and 2.1 for a while but had problems with it playing well with the darker MMS I was running.. I could not see the buttons well in direct sunlight.. I am taking today to reconfigure the phone (dumping ADW/removing clock from notification bar, and upping to SC 2.2)... then will take Blackish storm out for a new view..
Status
Ltabboisi
