[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
Haha thanks for the encouragement guys..I am so happy with my fully functional set up now...I can't flash a bunch this weekend..If the community ROM or ODIN package isn't here by Monday it may be go time..(by that time nitro will probably have 10 more releases anyway.. :0
EDIT: Plus I want to see how this comavolt fairs versus the stock ec10 kernel that came with 2.9.2..I was averaging around 3.5%hour drain with that.. we'll see how we fair on comavolt..
Jae im finally a big boy and graduated and flashed a rom:) whats up with the 4 lock screen function in Evil Fascinate, when i slide "TSM" it vibrates a bunch then reboots. what is it supposed to do?? LOL Lttwing 3.3 is fully functional im loving it right now actually.
You can call me dave man..I don't have a single wing more less a little one..haha :p
The team sbrissen lock screen did the same for me, as I am on Nitro Honeycomb 4.2...I just don't mess with it and use the epic lock.
It has to be there for a reason Dave man(sorry had to do that:D), Hopefully someone knows the answer. but i love the AOSP lock screen. Try out evil fascination after i fixed my force closes it has been smooth sailing. Got force closed on sammy keyboard and email, but now he has a keyboard flash fix and just clear data on stock email. Do it. just wipe both caches, painless. Was my first rom flash. (this is me pushing you:p)
I will use the broken record method of deterring your Evil (pun intended) peer pressure. "I will wait, you can't convice me" "I will wait, you can't convince me" "I will wait, you can't convince me"...but I find myself convincing myself...lol
If you get a sequence of vibrations then a reboot - that typically means that there is an incompatible app or an app is trying to start and is force closing in the background.
I have had this experience with themed components that were not compatible with the ROM I was running.. But that was back on DL09..
yah I dont know what it was set for though. acdragon28 in irc just told me that you can link that "TSM" button to anything u want. so i made it link to my handcent app. pretty cool feature. Dave i recommend that feature now that i know what it is. LOL
anyone know where to get the android peeing on apple bootamation, the link on the 1st page isn't working?
The TSM tab on the 4 tab lockscreen is a customizable tab you can use to open an app when you unlock the phone. Check the settings in the lockscreen app. You can sync an app with that tab.
Reactions: Lttlwing16
I'm on sc 2.9.2v, no theme ..wanting to try out that 4tab lock screen ..in the developers notes he recommends that you're "deodexed" before flashing ..I've seen this term several times but not sure what it means or if all the sc roms have it?
Also, I'm not as familiar with navigating the xda website and I'm not sure which link is the correct dl link I'm looking for ...there's a accurate battery/stock battery/asop answer?
Thanks in advance
Link must be broken... I have the non-flashable zip file if you want to push it to system/media.
Sorry about that guys - was cleaning house and accidentally nuked a few files.. Here is a CWM flash - link..
If other links go down let me know..
Thanks for providing the ani..
Thanks in advance
SuperClean 2.9.2 is deodexed... Deodexed is the process (end of a process) of removing a set of files so that the phone will boot faster.. almost all ROMs are deodexed.. Should be identified in the OP of the developer..
If you are referring to the sbrissen mods:
Acc Battery -||- Stock Battery
These are the links.. for those mods.
Reactions: sup3rchi3f
No problem JaeKar just helping out. I cant imagine how hectic it is trying to manage all these new releases and links.
Thanks in advance
Correct all SC ROMS are deodexed your fine. The link for the accurate battery/stock battery/ASOP answer is in #6 post of this thread under add ons and tweaks. Heres the link to sbrissens mod over at XDA
I'm going to downgrade to DL09 to get the ED01 update. After I get the ED01 modem I am going to re-root plus the CWM package by DroidXCon.
Can I flash Evil Fascination rom from eclair?
Or is there a better way of doing this?
IMMEDIATE HELP!!!
I tried flashing an overclock kernel and when rebooting, it would just simply boot right back into CWM. So I simply just went and reflashed my old kernel back on, after the wipe and now, it boots up and when it gets to the point where it normally virbrates one time and goes to the main screen, it vibrates, flashes, and goes back to the boot animation. It just keeps looping!!!
Please help me get out of the this!!
Gremlin69
