How to remove battery icon from lock screen?
Umzling
7
Since getting Verizon Nougat upgrade the only change I see is this battery icon on the lock screen which drives me crazy. I use Nova launcher. Anybody know how to get rid of this?
Thanks.
❓The quickest answer could be provided by your Phone carrier..
Contact them by phone-onLine or visited one of its Stores
I was just about to post this too haha
Updated today and seeing battery display on lock screen drives me bonkers
Went to Verizon today. They cannot remove it. They suggested writing to LG, which I guess is the next step.
I wrote to LG yesterday. I just received the response.
The battery icon cannot be removed as it part of the update to Android 7.0, Nougat.
To remove the message about slow charging, they suggest a factory reset as a possible workaround. Is this a cure? They don't say for sure.
I am not pleased. I'm not interested in starting over again.
I guess you've to reconsider the Unlikeable battery icon in the
unlocked screen..Samsung have similar feature called
AoD=Always on display it shows >>Date & Time
plus battery icon and 90% of users approved
The choices to remove a slower charging is the Factory reset
and to fix the battery icon-Switch to different phone..is upto You.?
Unfortunately as in our PC's-Not always is customized as We please
Screwgoogle
