how to reset direction lock on samsung j8?
  • Start date Start date
Welcome to Android Central! If you fail the unlock enough times, does it prompt you for a backup password? If not, then you'll probably have to do a hardware key factory reset (which will also require you to enter the Google account and password associated with the phone. Try not to forget your important passwords!
Pit
