[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
Hey I keep getting hung up at the Lg software update tool. at 30 percent it tells me to restart. gives me this.
15:00:41 : _IsConnectedPhone Call
15:00:41 : _IsConnectedPhone(0)
15:00:41 : 0 - NotConnected.
15:00:41 : 1 - Normal connect success
15:00:41 : 2 - Emergency connect success
15:00:41 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
tried unplugging it, plugging back in. installed the update tool in compatibility mode as well. don't know what to do. any ideas?
So it started the flash process, got to 30%, then complained about the cable?
Sounds like something is going wrong with the cable or drivers.
I've never seen it stop in the middle of a flash.
i need help
im stuck on the part where u open the windows prompt and idk what to do after i open cuz i dont see anything
Are you saying the windows cmd prompt doesn't show up, or it does show up but you can't find the files?
HI, I am trying to revert to LS670V9 and when connecting to phone gets to 100 per cent appears a window that reads: UPDATING IS NOT POSSIBLE DUE TO A FATAL ERROR WHILE THE LG MOBILE PHONE SOFTWARE UPDATE.
Please help!!!!!
Haven't seen that error. How far along are you in the process? At 100%, the phone should have rebooted and be in the process of restoring NVRAM. Is your phone booted into Android?
Please help!!!!!
I sometimes get that. Just do it again.
You shouldn't lose your data, but things may start behaving funny causing you to reset everything, or at the minimum wipe data/cache. Also whenever you do flashing, there is the chance stuff gets reset.
You should always backup your data before doing any flashing.
As to rooting, that will definitely not cause you to lose data and you will not have to wipe data/cache.
Do you reccomend a good free backup software to use?
If you want a full backup of what you have now, just do a nandroid backup after you root and install a custom recovery.
If you want backups at the application level, then I'd suggest Titanium Backup (again after you root).
when i do step (h)....it says path could not be specified. help please?
Do you have a directory C:\KP500-Utils-EN-v0.4.2
Which of the commands gave you that error (there are 4 of them in step h)
well im kinda new to this, so idk what im doing. but i did move the file to the cd, and i copy and pasted the commands and didnt work, am i supposed to put all of them as one sentence? or push enter every time...for example c: (enter) cd kp500-utils-en-v.0.4.2 (enter) etc....?
The phone do not reboots to Android, it reboots back to the Sprint ID screen and sometimes it does not reboot at all.
Here is the log:
23:51:14 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
23:51:14 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade23:52:30 : _IsConnectedPhone Call
23:51:14 : Start Date : 2011-03-10 23:51:14
23:51:14 : -------- Buyer Test mode ---------
23:51:14 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
23:51:14 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
23:51:14 : *****CheckOS Start********
23:51:14 : Microsoft_Windows_Vista Home Edition_
23:51:14 : *****CheckPCSyncPrograms Start*****
23:51:15 : PCSyncPrograms Not Found
23:51:15 : SetEmerModeAT()
23:51:15 : _IsConnectedPhone Call
23:51:20 : _IsConnectedPhone(1)
23:51:20 : 0 - NotConnected.
23:51:20 : 1 - Normal connect success
23:51:20 : 2 - Emergency connect success
23:51:25 : Checking the connection with the cell phone...
23:51:25 : dwWaitResetTime(40000 ms)
23:51:26 : Phone Mode(1)
23:51:26 : *****GetPhoneType Start*****
23:51:29 : Phone Type : CDMA
23:51:29 : *****Start GetPreviousStep*****
23:51:29 : _GetPreviousStep(dwStep:0xffff)
23:51:30 : _SetPhoneNumber retval=1
23:51:30 : *****GetPhoneModel Start*****
23:51:32 : *****GetPhoneBinaryVersion Start*****
23:51:32 : Phone Bin Version : LS670ZVC_11
23:51:32 : *****Get ESN / IMEI / MEID Start*****
23:51:43 : ESN/IMEI/MEID : 8030FE8B
23:51:43 : *****GetPhoneNumber Start*****
23:51:46 : Phone Number : 8030FE8B
23:51:47 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 8030FE8B, M23:52:36 : _IsConnectedPhone(1)
odel : 23:52:36 : 0 - NotConnected.
23:52:36 : 1 - Normal connect success23:52:36 : 2 - Emergency connect success
23:52:36 : Phone Mode(1)
23:52:36 : m_dwBootWaitTime(35937)
23:52:36 : Checking the connection with the cell phone...
23:52:36 : dwWaitResetTime(30000 ms)
23:51:47 : *******CheckBinVersion***************
23:51:47 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVC_11)
23:51:47 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
23:51:50 : _GetAuthMark : wAuthMark(22557)
23:51:50 : Wait 3Sec
23:51:55 : _SetAuthMark Ok : wAuthMark(22557), PhoneMode(1)
23:51:55 : *****Start _GetBatteryLevel*****
23:51:58 : Battery(5)
23:52:00 : ResetPhone...
23:52:00 : Checking the connection with the cell phone...
23:52:00 : dwWaitResetTime(40000 ms)
23:53:06 : _IsConnectedPhone Call
23:53:11 : _IsConnectedPhone(1)
23:53:11 : 0 - NotConnected.
23:53:11 : 1 - Normal connect success
23:53:11 : 2 - Emergency connect success
23:53:11 : Phone Mode(1)
23:53:11 : Call _ModeOffline()
23:53:12 : *****CheckPCSyncPrograms Start*****
23:53:13 : PCSyncPrograms Not Found
23:53:14 : CLGMobileHttp Class ?Ҹ????.
23:53:14 : CLGMobileHttp Class ?Ҹ?...
23:53:14 : ****************CheckAndDownload********************
23:53:14 : ******Extract Start LS670ZV9.cab*****
23:53:14 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
23:53:14 : ExtractInfo Error(0)
23:53:14 : Extract cab file error.
23:53:14 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
23:53:14 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
23:53:15 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
23:53:15 : CLGMobileHttp Class ?Ҹ????.
23:53:15 : CLGMobileHttp Class ?Ҹ?...
23:53:15 : Page_Error ?κ??Դϴ?
23:53:15 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Any sogestion will be appreciated.
Please perform step (h) and post the output.
when I perform step [h] and type C: dir nothing happens. no such dir appears. if I type just dir then appears my drive C: with information that have nothing to do with LS670ZV9.cab
A am lost.
Any help would be appreciated.
Riyan75
