[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
Re: [How-To] Rooting LS670ZVD with GingerBreak (no reverting and
1) ADB isn't something you install to your phone.
2) Do you have the correct drivers installed?
well i know that i just cant get the phone to comunnicate with my pc and i installed every driver i can think off from android sdk to all i could fnd in the web
Try the LG Mobile Support tool. Just install it and when it opens click "USB Driver" and choose the right one (Sprint LS670).
Reactions: bebe43
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\BEBE>cd c:\androidzvd
c:\androidzvd>adb shell
error: device not found
c:\androidzvd>
still dont find it dont know what to do can i do this by using a sdcard
c:\androidzvd>
Did you install the correct drivers like I said?
I installed the drivers and still nothing .
Okay I know I am close! but I need a little help...I got the # prompt briefly (i think i followed the directions correctly)... then hit exit and the prompt went back to $...
I know i need to do the recovery first, but haven't had any luck...how to get back to #?
I only get $ doing ./adb shell
See below:
[!] dance forever my only one
# mount -o remount,rw -t yaffs2 /system /system
# cd /data/local/tmp
# cat su > /system/bin/su
# cat busybox > /system/bin/busybox
# cat Superuser.apk > /data/app/Superuser.apk
# chmod 4755 /system/bin/su
# chmod 4755 /system/bin/busybox
# exit
$ exit
Thanks!
Thanks! got it!!! now on to the next steps...i feel like a giddy little schoolgirl! hahhah
Thank you so much for this. I've been wanting to root my phone for awhile now.
Okay, so I have done a backup...
Can someone point me to the right thread (My brain is mush- been reading al the threads and now can't find my way back to where I should be)
1-I want to get rid of all the sprint bloatware! (is there a thread of how to do this and which files should not be removed?)
2-should i install a ROM first?
3- Thank you for all the help- the forum is truely kind to newbies and i for one appreciate it!
Ok, I'm running into a few problems, probably self-inflicted, but any guidance would be appreciated...
I unzipped the exploit contents into its own directory, and ran adb from there.
I copied the necessary files over to the tmp directory and chmodded to 777, no problems. I let the Gingerbreak app run for about 10 minutes, never got root. So, I attempted to mount the file system, and got an "operation not permitted" error.
Any ideas what I'm missing or leaving out?
TIA
Ok, this thread is way tooo long! :) So, I ended up using Gingersnap to root my phone last night. Ended up having to use an XP computer rather than Windows 7. Thanks for the info.
Lol... I just posted on how rom manager is not for our phone. Read that post. Also yes you flash it thru recovery
Sent from my PC36100 using Tapatalk
Reactions: ritzcrax
TIA
Sounds like you never mounted write on it.
I would suggest starting from beginning and see how it goes.
9) Mount the /system partition read-write
10) Change to the /data/local/tmp directory
Quote:
cd /data/local/tmp
11) Copy su and busybox to /system/bin
12) Set correct permissions on su and busybox
13) Exit the shell
Quote:
exit
exit
r3dpuk3
