- Dec 27, 2010
- 2,476
- 2,803
- 0
I cant find the answer to this question and hopefully this is the correct place to ask it.
I ran through the install, everything appears fine, but how to I get Superuser access after I exit.
I thought I simple do:
But I get a Permission Denied message. Is this not the correct way to get su access? do I use busybox to run su?Code:adb shell su
Ultimately I am trying to be able to set up xionia recovery but cant get back to su access to mount/remount and setup the flash_image.
BTW I have done this 3 times now. Each apparently successful, not sure since I cant get back to the su command prompt.
Thanks alot;
When you issue the "su" command, your phone must be ON and not in a locked state. You will need to expressly allow the prompt that appears after you issue the "su" command. Further use of the "su" command after that will go unhindered
