[How-To] Rooting LS670ZVD/ZVH (100% automated) + ZVJ (automated)
Re: [How-To] Rooting LS670ZVH (automated, no revert/wipe needed)
lol errr sorry that time it worked lol
forgive me please you rock!
Great, I'm glad it worked for you.
I'll add a note about the sdcard removal message. It is an expected message, which you are supposed to ignore, which it looks like you did.
This is actually a complete different issue than your first post. This time, you can access /sdcard/000root.
However I uploaded an enhancement earlier and missed a file in the zip archive. If that file had been there, you'd be rooted right now. I already fixed the zip archive, but you probably downloaded before the updated zip got put up.
Please re-download zvhauto.zip and try again. Apologize for the inconvenience.
What I ended up doing is downgrading back down to ZVD from a link that someone had on this forum and it worked. Now I'm running the ReBORN ROM, [ What I really want is 2.3 Gingerbread with CyanogenMOD. Will i need to manually upgrade to ZVH or can i just install the rom with the Xionia clockwork (i forgot to mention that I also upgraded the clockwork mod).
All the CM7 ports are based on ZVD, so you should be fine the way you are. If you upgrade to ZVH then the data won't work on the CM7 ports.
so is there a one click root yet... if not do you know how much longer.
Thank you, my phone was rooted the first time I tried your automated program. I did root check, have Superuser (updated). Superuser permission has been asked and granted. All the Zerglings are celebrating (noisy bunch)...My question is this..Besides having Superuser listed with my apps, how else can I tell the phone is rooted?
If you download Titanium from the market and run it, it'll ask for root permissions on the phone's screen and assuming you accept, it'll work properly on your phone.
If you type "su" in "adb shell" or "terminal", it'll ask for root permissions on your phone's screen and assuming you accept, you'll see the "#" prompt.
If you reboot into recovery (power off, power + vol-dwn + home) you'll have Xionia CWMA (allows nandroid backup and installing custom roms)
There are other ways, but those are the most common things people do with root.
Reactions: Jean-Marie
Thank you. Will check it out after work.
Thank you, my phone is rooted!:) Now....how do I unroot it? Will unroot methods listed in the forums still apply? I'll check it out. Thank you, my phone is rooted! :D
See Reference Section C in the 2nd post.
Skip all "install-*" scripts except "install-unroot.sh"
Thank you. Nice to know in case I have to take the phone for repair.
Thank you. Nice to know in I have to take the phone for repair.
If you are taking it for repair and really want to undo everything, even the custom recovery then, prior to "install-unroot.sh" you should run "install-vd.sh" so it would look like this:
$ su
# cd /sdcard/000root
# /system/bin/sh install-vd.sh
# /system/bin/sh install-unroot.sh
Re: [How-To] Rooting LS670ZVH (100% automated, no revert/wipe nee
See first post:
Added new AUTOMATED functionality
- Uninstall root
- Install Xionia CWMA Recovery
- Install Stock LG Recovery
- Manual Install
- Stop ADB Server
Re-wrote scripting system
Added new MENU system
17611d1321031451-how-rooting-ls670zvh-100-automated-no-revert-wipe-needed-root-large.jpg
I've spoken English all my life but I just can't figure out how to say thank you ENOUGH!! THANK YOU!!! This worked like a charm on my LG Optimus S
Glad you got it working. It is good to hear success stories.
Getting ready to
INSTALL persistent root
Please verify ALL of the following:
SD card is INSERTED (do NOT REMOVE even if it says "safe to remove")
USB Debugging is ENABLED
USB Storage Mode is DISABLED
LG USB/Android drivers are INSTALLED
Phone is connected to USB port and recognized
Press any key to continue . . .
Phone is turned ON
Phone screen is UNLOCKED
Waiting for device to be connected [press CTRL-C to cancel]... Found device
Proceeding with install
---- BEGIN LOG ----
...Proceeding to copy necessary files...
cannot stat 'copy2tmp': No such file or directory
cannot stat 'copy2sd': No such file or directory
...Running Zerg exploit...
/system/bin/sh: Can't open /data/local/tmp/install-zerg-auto.sh
---- STATUS of ZERG on PREVIOUS few lines ----
cd: can't cd to /sdcard/000root
/data/local/tmp/sh: not found
---- END LOG ----
Check the STATUS of ZERG above, this exploit depends on a
condition which doesn't always hit
If you see
[-] Zerglings did not leave interesting stuff
Then the exploit did NOT work during this pass
After reboot you'll need to RE-RUN the root install script
It may take SEVERAL attempts before the condition hits
If you see
[+] Rush did it ! It's a GG, man !
Then the exploit was SUCCESSFUL. Script will reboot, then you are DONE!
Keep in mind, should you CHOOSE to run "su", you will be prompted
for permission on the phone's screen during the first run. If you
do not ALLOW this prompt you will get a "permission denied" error
turn ON phone
make sure you have EXITED the lock screen
run "su" from "adb shell"
accept the prompt on the phone's screen asking for root permissions
It is NOT required to run "su". You ARE ROOTED regardless.
Getting ready to reboot...
/system/bin/sh: Can't open /sdcard/000root/install-cleanup.sh
Rebooting
If it takes LONGER than 30 seconds to initiate reboot
manually reboot using the POWER button to power OFF/ON
E:\zvhauto>
Am I missing something?
Did you unzip all the files and directories in the zvhauto.zip archive?
The install is complaining it cannot find
C:\zvhauto\copy2sd
and
C:\zvhauto\copy2tmp
I downloaded zvhauto.zip from the first post and verified these are in the zip file so it must be something on your end causing them to not be found.
Your quite right, I forgot those two when I was unzipping it.
Thoitrangyozu
