[How-To] Rooting LS670ZVD/ZVH (100% automated) + ZVJ (automated)
Re: [How-To] Rooting LS670ZVH (automated, no revert/wipe needed)
It worked! I am now rooted. A special thanks to SF Hub to help me with the process.
Glad you got it working. Care to provide some feedback?
Was it easy to use? Did you run into any difficulties? Anything that wasn't clear? etc. etc.
Hopefully it mostly worked out of the box with few issues.
go im trying to get this to work but my phone wont show the message "su".
its not locked im doing everything u told me.. idk wats happening. wat do i do
I'm guessing that you already successfully ran the rooting script and are just unsure what "su" is.
I added a more detailed explanation in the first post which will hopefully clear things up for you:
Note #1 - "su" is a program that allows you to request root privileges (while in "adb shell" or "terminal"). It stands for "switch user" or "superuser" depending on how far back in history you look. This was installed for you as part of the rooting process. Many instructions you'll see on forums ask you to run "su" to gain root privileges. The first time you run "su" (from "adb shell" or "terminal") you need to grant permissions on a prompt that comes up on the phone's screen. If you don't realize that, you'll get "permission denied" and think the root didn't work. Make sure your phone is not on the lock screen or you won't see the prompt. It is NOT a requirement that you run "su"
I had problems installing root, when I realized that i didn't copy the files to the c:/. I realize how important it is to follow directions exactly.
I see the superuser icon and I've begun installing programs. I got permission, so I suppose I'm ok. I haven't run anything from the shell or terminal (don't know how), so I haven't come across that.
I loaded adobe flash and it worked on the stock rom ( i followed the directions of the post), and I found that if i reboot, I lose the copied files that you are suppose to put (for those running stock rom). I'm hoping that a version will be developed that will work on stock.
Anyway, I'm pretty happy. I have pretty much everything I need (except flash). I tried downloading a move all files to sd program and it was blocked. Any ideas?
Thanks again for your help, and I look forward to being a part of the community.
Wow did I read that right it will install xionia too? :)
Yes, everything is automated (assuming you are already on ZVH)
This was a piece of cake. I had to run the install twice since the first time it thought the device wasn't connected. Should make my girlfriend much happier with a new ROM instead of that glitchy stock GB that Sprint put out OTA. It's been quite some time since I rooted my EVO 4G, so I can't compare the process, but for anybody that reads carefully, this is perfect.
Glad it worked for you. Thanks for the feedback.
I improved the script so it waits for your device to be connected before continuing with the install.
I've followed all of the instructions and run the scripts and gotten a success message and initiated the reboot. However, upon reboot there is no superuser app and trying to run SU from adb shell gets denied. Can you help?
My mistake. I missed a file when uploading an enhancement earlier. The zvhauto.zip in the first post has been updated and should work now.
I'm having trouble with this.... I'm getting:
[*] Sending 157 zerglings ...
[+] Rush did it ! It's a GG, man !
/data/local/tmp/sh: Can't open install-root.sh
It looks like I don't have install-root.sh. I can't find it anywhere in the zip archive either.
Sorry, my mistake, I missed the file when I updated with an earlier enhancement.
Fixed package is being uploaded now.
EDIT: Fixed package is in first post. Please re-download and it should work. Apologize for the inconvenience.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Alex>c:
C:\Users\Alex>cd \zvhauto
C:\zvhauto>install-auto
Getting ready to install persistent root...
Please verify ALL of the following
Phone is booted into Android
SD card is INSERTED
Bootup Media Scanner process has COMPLETED
USB Debugging is ENABLED
USB Storage Mode is DISABLED
LG Android USB drivers are INSTALLED
Phone is connected to USB port and recognized
Press any key to continue . . .
Phone is turned ON
Phone screen is UNLOCKED
Waiting for device to be connected [press CTRL-C to cancel]... Found device
Proceeding with install
push: copy2tmp/zergrush -> /data/local/tmp/zergrush
push: copy2tmp/install-zerg.sh -> /data/local/tmp/install-zerg.sh
push: copy2tmp/install-zerg-auto.sh -> /data/local/tmp/install-zerg-auto.sh
3 files pushed. 0 files skipped.
420 KB/s (22819 bytes in 0.053s)
push: copy2sd/000root/xionia_cwma_12518.6.img -> /sdcard/000root/xionia_cwma_125
18.6.img
push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk
push: copy2sd/000root/su -> /sdcard/000root/su
push: copy2sd/000root/recovery_vd.img -> /sdcard/000root/recovery_vd.img
push: copy2sd/000root/install-xionia.sh -> /sdcard/000root/install-xionia.sh
push: copy2sd/000root/install-vd.sh -> /sdcard/000root/install-vd.sh
push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
9 files pushed. 0 files skipped.
3028 KB/s (13609185 bytes in 4.389s)
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00015118
[*] Sending 149 zerglings ...
[*] Trying a new path ...
[+] Zerglings caused crash (good news): 0x4011bcf4 0x0064
[*] Researching Metabolic Boost ...
[+] Speedlings on the go ! 0xafd25157 0xafd391a7
[*] Poping 8 more zerglings
cd: can't cd to /sdcard/000root
/data/local/tmp/sh: Can't open install-xionia.sh
Check the status above, this exploit depends on a condition
which doesn't always hit
If you see
[-] Zerglings did not leave interesting stuff
Then the exploit did NOT work during this pass
After reboot you'll need to RE-RUN "install-auto"
It may take SEVERAL attempts before the condition hits
If you see
Then the exploit was SUCCESSFUL. Script will reboot. You are DONE!
Keep in mind, should you CHOOSE to run "su", you will be prompted
for permissions on the phone's screen the first time it is run
turn ON phone
make sure you have EXITED the lock screen
accept the prompt on the phone's screen asking for root permissions
It is NOT required to run "su". You ARE ROOTED regardless.
Getting ready to reboot...
/system/bin/sh: Can't open /sdcard/000root/install-cleanup.sh
Rebooting
If it takes LONGER than 30 seconds to initiate reboot
press CTRL-C and manually reboot
[[[[ok...now i've been trying to do this several times and no matter what i do, everytime the command prompt says that it is sending the "zerlings" the sdcard keeps saying that it is safe to remove. It's like the phone just automatically ejects the sdcard during this step.
I know its says " [+] Rush did it ! It's a GG, man !" but it still doesn't send the zerlings.
I'm kinda lost and I need help. I've rooted several other phones before and I've never had any problems. Now the situation with this phone is that I had rooted the phone when it was a ZVD and then my father gets an update option a couple months later and decides to update it. Now it's running ZVH and I can't root it for the life of me. PLEASE HELP!!! ]]]]]
C:\zvhauto>install
464 KB/s (22819 bytes in 0.048s)
18.6.img
1328 KB/s (13609185 bytes in 10.004s)
C:\zvhauto>adb shell
$ cd /data/local/tmp
cd /data/local/tmp
$ /system/bin/sh install-zerg.sh
# cd /sdcard/000root
cd /sdcard/000root
# /system/bin/sh install-root.sh
/system/bin/sh: Can't open install-root.sh
[[[[[This is what happens when i do the alternate method...I'm not sure what I'm doing wrong or if i should run a different guide to root my phone. again please help me]]]]
Do you have your SD card inserted?
Did you turn OFF USB Storage Mode? (drag down the notification bar and tap on "USB Connected")
Can you type
cd /sdcard/000root
/system/bin/ls -l
and post the output
This problem is because somehow you aren't able to access the /sdcard/000root directory. Probably something happened to the mount point.
It is supposed to say safe to remove. The exploit involves that section of code. It however isn't supposed to unmount your sdcard. Did you actually physically remove your sdcard? If not, I'll have to work with you to figure out what is going on in your case.
cd /sdcard/000root
This is actually a complete different issue than your first post. This time, you can access /sdcard/000root.
However I uploaded an enhancement earlier and missed a file in the zip archive. If that file had been there, you'd be rooted right now. I already fixed the zip archive, but you probably downloaded before the updated zip got put up.
Please re-download zvhauto.zip and try again. Apologize for the inconvenience.
ok so i tried this twice it didn't work, is there some trick i am supposed to do ie put in like factory recovery?? all i did was turn on my phone enabled usb debugging, rebooted phone, connected usb cord and then ran the install-auto. both times it failed will try a third time, just wondering if i am dumb and not doing something right.
Could you say what is failing? Is the exploit script not working (ie you are seeing [-] Zerglings did not leave interesting stuff ) or is the installation of persistent root not working? If you see error messages, please post those.
first off wow to the spead in which you responded!!!! thank you!!! erm idk exactly it just says that it failed in this pass and that it will reboot and to push any key to reboot. just tried it again and that's what it said again
SD card is INSERTED
Phone is turned ON
384 KB/s (22819 bytes in 0.058s)
18.6.img
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
11 files pushed. 0 files skipped.
3074 KB/s (13610357 bytes in 4.323s)
Installing persistent root... Done
Installing Xionia CWMA Recovery... Done
If you see
If you see
turn ON phone
at the first line where it said it was sending 149 zerglings or whatever my phone then said sd card is safe to remove....just noticed as i was paying attention to everything this time. sorry i am a noob when it comes to all this stuff and really appreciate you patience
Pst Ajode
