how to stop vibrating on text receive??? help!
ryanfoley613
Active member
Nov 12, 2011
29
hey guys, so first I just wanna say im pretty good with these phones ive had android for about a year now, started with a droid2 then xperia play and now I just got my droid3....I love it
however I can not figure out how to turn off vibrating when a text is received, I have vibration set to never in the vibration settings....someone help i hate it!
thanks!
thanks!
In the messaging app, menu->messaging settings. At the very bottom, is "Vibrate" checked? If you uncheck it, that *should* stop vibration on receiving SMS/MMS messages.
I had the same problem, and you just helped me solve it. Thank you SO MUCH!! I thought I turned off all vibrations, but the phone would still vibrate AND ring when a text came through. I was going insane!:p! You're a life-saver
I'm so glad this was posted I was driven crazy last night with the constant buzzing of the text vibrating.... I had looked in phone settings but not that app. Thank you so much !
go to 'message setting' >go down and select 'Notification setting' > uncheck 'Vibrate' option !!
i can uncheck the notification icon but I cannot uncheck the vibrate(it is inactive)
Thanks dude..
Menu ----> Messaging---> Setting ---> Notification(Vibration while receiving MSG) Unchecked it.
Re: how to stop vibrating on text message receive??? help!..
Hi! How about FB msgs, how to stop vibrating when receiving msgs? Pls help. Thanks.
Viber is making me insane with that vibration ...
I can't figure out how to stop messages to vibrate.
Any solution?!
khatunkhatunc
