How to successfully uninstall/optout of Xapush ads??
I want to opt out on my Kindle Fire, but Google Play doesn't support this device to be able to download the optout app. Any ideas?
THANK YOU!!! I just downloaded the Addons Detector and it worked like a charm. Found it right away. Was my music paradise app. Thanks again!
Thank you , air push detector seem to have worked for me it was that answers / cheats thing for my 4 pics 1 word game
Hey guys here are the 2 easiest ways to get this junk off your phone. The quickest is the next time you get an ad, press and hold the notification for a second or two. A small screen will appear that says ad info. Click on the ad info screen and it will reveal the app that's culprit. Uninstall the app and you should be good. If that doesn't work go to your app store and download the app Airpush Detector. Once installed and opened it will reveal the culprit. Uninstall the app that's causing the ads then uninstall the Airpush app since you won't need it again and you should be good. Hope this helps, take care.
Hi,
Anyone else found a remedy to this ad-pushing issue and how did you solve it ?
Not sure if you found a remedy, but I can't bother to go through all the posts.
I also had this issue after I installed something on my BlackBerry Z10. My admin privileges were void when trying to manually remove the corrupt folder from my device's directory. I installed an app called "File Manager" and was able to manually delete the bugger right away. Painless and seamless, it took ten seconds to find and delete it.
Hope that helps you all.
Brilliant, thanks for this. I kept it pressed for a few seconds as you said and uninstalled the culprit.
Tfunz
