How to transfer contacts from Blackberry to Galaxy S4
Faisal385,
Thanks so much for posting your video! This worked perfectly with my Blackberry Bold 9700 and Samsung Galaxy S4 Active!
Re: How to transfer contacts from Blackberry to Galaxy S4 Mini
Question: I have the Samsung S4 Mini Duos. how do I create 2 SEPARATE contact lists, ie; one for my personal contacts, one for my business contacts. my contact lists are in the thousands so they cant be put on the sim's.. I don't want them merged together for obvious reasons.
THX
Just turn on the Bluetooth in both devices. In blackberry > bluetooth options, click Transfer Contacts. Simple...S4 receives the VCF file. And voila, you have all contacts stored in S4 now :)
it takes not even 2 secs.
You may follow the guide below:
1) Plug in Blackberry to computer
2) Run Blackberry desktop software
3) Choose which software to sync contacts with (Outlook, Address Book etc...)
4) Sync Blackberry to that software
5) Unplug Blackberry
6) Plug in iPhone....make sure that auto sync is turned off...
7) On INFO tab in iTunes....check sync contacts...use same program
8) Sync iPhone..
9) iPhone will ask if you want to merge or replace data...select merge
Re: How to transfer contacts from Blackberry Z10 to Galaxy S5
Hi guys,
I have issues syncing my yahoo contacts from my blackberry z10 to my samsung s5.
i unfortunately do not have the option on the z10 to sync contacts via bluetooth.
Anything else tried and tested that actually works??
so over this Blackberry issues now!!
#PleaseHelpUrgently.
Did you ever get a resolve, I am having the same issue. Have tried smart switch, bluetooth smartio, none of them have worked - I really need my calendar mostly and the other important contacts that did not come over with other methods like the ones stored on bblink and my home computer outlook. I am going to try Kies next. Trying to go from a Q10 to a Galaxy S4
Use "InTouch". When I went from my Z10 to my Galaxy S4, I had all of my contacts on my new S4 before I walked away from where I bought it.
mrtalha
