[How-To] Unlock, Install SU, Custom Recovery
Status
Not open for further replies.
Why do people hate clockwork?
How does one backup the RSA keys?
I don't hate clockwork at all, i just prefer Amon_ra. When i started, that was the only option so i stick with it. I find some features i use frequently (mount as USB, wipe dalvik) tucked away in sub-menus on CW which causes more button presses while those same features in Amon_Ra are centrally located (mount USB is #1 option, Wipe dalvik is conveniently located with wipe data and wipe cache).
Oh ye I noticed that too. when I switched my LG to CW menus were all over the place. Wipe cache was in one place and davlik was buried inside menus
Hmm weird problem. I unlocked bootloader, installed and rebooted into clockwork but now when I select backup restore and press power button all i get is hat with orange semi circle arrow. Any ideas?
Nevermind. Re flashed CW and all good. running nandroid now
Would someone please point me to the file I need and Terminal commands to root this on a Mac? I would appreciate it. There doesn't seem to be any one definitive way I can see.
Ok....it doesn't matter what I do. I have drivers installed and everything. When I run "adb reboot bootloader" it boots into bootloader/fastboot just fine, but when I type "fastboot oem unlock" , I get " 'fastboot' is not recognized as an internal or external command, operable program or batch file".
WTF?!
WTF?!
In your CMD window, make sure that change to the directory on which "fastboot" is located.
I too was also missing the file but it's rebooting into CW correctly. Now I need find a decent kernel and ROM
what exactly doesn't work? u only need to install PDANet to get drivers
Not sure... I do just what PDA says, but when I plug my phone into the computer, the computer fails to recognize it and PDANet just sits there doing nothing...
Do u get a little popup that says drivers weren't installed? If you want to do remote support session PM me and we can use teamviewer app to connect and I can take a look
Unlocked! Reinstalled fastboot drivers and used different USB port and it worked like a charm.
Status
mrrice360274
