How to use a new not activated OV on PPC
Why it is illegal to switch carrier:eek:? I bought the phone, it is mine now, I should be able to use it anyway I want I think. :D
It's not illegal to switch carriers or phones.
What is required to put a non-VM phone onto VM however can run you afoul of the law and VM.
To switch a Sprint or Verizon phone to VM, you have to copy the ESN (similar to the VIN number on your car) from a legitimate VM phone, to the second phone. This is sort of a grey area in terms of federal law, and is flat out illegal in some states. It is also a terms of service violation on VM, and against the rules to discuss the methods to do it on almost every forum.
Back in the early 90's copying ESN numbers or "cloning" was a big thing, and carriers lost tons of money because of it, lots of laws were passed to stop it. The federal law regarding it was later amended to make it only illegal to do if you are doing it to defraud the carrier.
The laws that many states put in place however were never changed or never took this into account. Missouri is one of those states, it's flat out illegal to clone a cell phone for any reason there. However, there are lots of laws that are outdated and no longer enforced. So long as you aren't causing trouble the carriers and states tend to ignore it.
Many people are unaware this law was changed and scream it's illegal any time anyone mentions it. Forums don't like trouble, and some have had the feds and others come down on them for spreading the information, so most have a rule that you can't discuss the methods involved.
Here is what changed for those curious...
Back in the 90's you could get a phone at a swap meet (for around $150 and usually stolen) then pay the same guy around $300 and you would get unlimited service for 3 months or more. You couldn't receive calls, but you could make them. I knew people using 5k minutes or more a month on cloned phones. Cell service was EXPENSIVE back then, so this was a crazy deal. You found lots of people with a pager or a cheap cell phone to receive calls, then they would call back on the clone phone.
Today,
Would you pay someone $100 for a phone, and $500 to set it up so you could only make outgoing calls for 3 months? No. You can get an Iphone with unlimited minutes incoming and outgoing minutes for that. The economics changed on cell phones to the point that cloning no longer makes economic sense. Most people doing it today are only doing it so they can use a phone on a different carrier, such as using an Evo 4g, 3d, Epic, or Optimus Black on Virgin or Boost.
All dialing codes do is activate a built in menu/script/progam, and they are device and vendor specific, grabbing some random Verizon code and typing it into your Optimus will do nothing. This is also why Virgin codes (and the activate app) doesn't work on CyanogenMod.
Yeah, I get that. I've been trying not to flat out say "Do this and it will work" because I obviously don't know for sure, but I would think that all the files that are being flashed to make the V Verizon-ready would give the capability for the Verizon shortcodes (like *228).
it doesn't work like that. But if you want easy access to to the data profile or whatever use anycut from the market or if you really need some dialer codes flash the sprint rom (not the kdz or updater just the rom) it's not that cut and dry but it will help you out.
Also I noticed that some people awhile back had some issues with getting rid of the yourphonenumber@mdata.vmobl.com there was also a solution of erasing a file but an easier route which also works on the lg marquee (couldn't get rid of @hcm.sprintpcs.com) use anycut make a shortcut to CDG2 open it and go to data setting select PPP carrier and change it from sprint to Undetermined it will reboot your phone but from then on you can just use dfs or whatever it is your using to fix the nai and uid.
EDIT: I realize that I said an easier method but what I should of said was an easier method for me since some might find the other method easier
pamatika
