How to use S7 as TV remote control?
  • Start date Start date
A
AC Question
saw/lost TV remote app on my S7. Want to find again and install. Where is it?
The S7 doesn't have an IR blaster which is why Peel is not on the device. If you have a smart tv there should be an app to control the TV over a wifi network.
Comcast also has a remote app, if you have their X1 platform.
Try Samsung Smart View app in the the play store. It may be a workaround for you.
If you feel like throwing some money at it you could buy a Logitech Harmony hub-based remote which will control all your devices and replace all your remotes and has an Android and iOS app which you can use as a remote controller.
ijessicadsouza
