How's the battery?
No battery issues for me. I don't typically keep track but battery life seems bettet
@ 120hz all day, I just went over 9 hrs SOT with 20% left. I'm a happy camper right now.
S20 5G: 720p, 60hz, 6am - 6pm, 2 hours 59 minutes SOT, battery at 37%. That's pretty crappy in my opinion.
I would advise all people with these phones, give it time to learn your usage patterns. I'm confident that after having the phone for 1-2 weeks you will see the phone balance out when it comes to battery life.
There will always be a difference in battery life when you use Wi-Fi or LTE.
Just a suggestion, maybe it will be clearer if you were to state the model you are using too ? S20/S20+/Ultra
Im particularly curious on the S20 with 120hz battery usage...
I've got an S20+, and I'm pretty disappointed with the battery life so far. To the point where I'm concerned it's faulty.
It seems to be using around 10% an hour when I'm walking around (with the normal use). This is with the screen on 1080 / 60hz.
It's just finished its learning phase, so I'm going to give it a full recharge, and see what I get. If it's still the same, then I'll try and get it replaced.
The other thing I've noticed is that it won't charge with my normal multi-charger (Satechi), unless I switch it completely off! Wireless charging works fine, and it also works with the supplied Super Fast charger, so it must be an issue with the charger. However, it worked fine with my S10+.
DonJrPlayz1234
