Tadrift
- Aug 19, 2015
- 132
- 0
- 0
Those pictures of the phone are clearly stress bends from being bent. Most likely over time. No offense, but they don't just happen for no reason. I keep my phone (a G3) in my front jeans pocket and sometimes while working and deep bending I can feel the stress against the phone. I sometimes have stood up and pulled my phone out just see if I did any damage, in particular a cracked screen, as the body is plastic.I wouldn't blame LG if something happened.
With your issue, you are doing something that is causing it. With that said, I am not suggesting it isn't a build flaw in the phone and it is all your fault. It is definitely worth going after them for a replacement. Because something they consider abuse is something you believe is normal use. It can be a fine line. If it were me, I would still try to figure out what caused it. Even if it doesn't seem like it should harm the phone. Everyone going with a metal build these days and with thinner and thinner metal to keep costs down, so likely you might do it to another phone.
You might still try Google to get some help, because it does have their name on it. Even if you didn't buy it through the play store. Google sold it to Best Buy to resale to you.
