HTC EVO 4G LTE: Wifi tether not working (im rooted)
Re: Wifi tether not working (im rooted)
Thanks....4 days of searching...you just fixed my Note II
Im trying to use the wi fi treve method and i keepgetting an error for routing fix whats the issue?
Are you rooted?
Yes I'm rooted with s off i had the stiock rom and tried and also alterrom, I have not tried with the rom im on which is nitrous i am on Sprint.....thx for your time please respond if you can help
Believe it or not, I have never rooted this phone, so I am not going to be much help.
I as well have tried all 3 suggestions. Nothing works. Using optimus g version 4.1.2 and kernel 3.4.0 wifi tether keeps saying "tethering started with errors. Check logs." I checked the logs and it says file doesn't exist. It will also ask if im rooted, i am, SuperSu. Also says "you are in an unknown state. Try rebooting." And of course it doesn't work. Uninstall, reinstall, nothing. :'(
SykoKU on my I don't have mss clamping on wifi tether treve on my Sprint note 2. I keep getting the message started with errors. What do I do?
solo1, I don't have mss clamping? Could that be the reasong why I can't get it to work?
I have the same problem as BuBu Mulero
Sent from my SPH-D710BST using AC Forums mobile app
amin2k019
