HTC One (M8): Battery problems
Re: Battery problems
Are you using Hangouts for video calling or just messaging? Also media server is a little high, you using a sd card with a lot of media files on it? And lastly, mm-qcamera-daemon is a known bug in KitKat and a fix is in the works with Google. To help resolve battery drain with it, kill the camera and any apps using the camera after use.
I just use hangouts for video calling. I have a sd where all my pictures go.
Sent from my HTC One_M8 using AC Forums mobile app
Does your battery get at all hot when charging? You do seem to have a lot running in the background. It seems you are a heavy app user also?
Sent from my HTC One_M8 using Mobile Nations mobile app
Yes it has gotten a little warm while charging. I deleted "hay day" which is a game that seemed to be draining my battery. I'm still at 37% and haven't charged it since its overnight charge.
I would like to chime in and say that I have also seen noticeably worse battery life since the recent update from Verizon. Very frustrating-- the initial battery life was really great.
iklansn
