Huawei P10 notification problem
Manvir Phull
3
Notification on lockscreen disappears after unlocking phone, shouldn't it only disappear after opening or swiping the notification ?
That's typically the way it works on Android and how it works on my honor 8.
Is this all notifications or only specific ones?
Its for all, I've been using a Galaxy S6 edge before and generally the notifications would stay on the lockscreen until I open the notification or swipe it off the screen. But for the P10 they all dissapaer after unlocking the phone, guess this is how Huawei has it set, thanks for the reply tho!
You guys should contact Huawei customer support. They might be able to incorporate a fix into a future update
