- Feb 10, 2016
- 4
- 0
- 0
Hello!
I have the phone for like a month now and since I`ve got it, I have some sound problems. Mostly application ones. First I don`t have the facebook sounds like the pop one. SOMETIMES the sounds when receiving a msg (happens with calls too) are louder when the phone is unlocked and even louder when I`m using the application I`m getting a msg from. This happens with Messenger, Viber and Whatsapp. Where with Viber, when I`m chatting with someone and I get a text there is sound notification, which I can`t turn off. Like the outgoing one, but the other way around. There are more similar problems I`m getting with the sound, but these are the most annoying ones.
Another issue I have is with the keyboard - when chatting and I tap on a letter, it uses it twice.
Happened once that I was getting a call and the phone was in my pocket. When I got it out and tried to answer, it wouldn`t work. The display was responsive (unlike my S4, which wasn`t when I had this issue), but it just wouldn`t work.
Since I got it I was trying to figure out if these are common problems for the model or it`s just mine.
I`d appreciate your opinions!
