Huawei P8 not recognized by any PC
  • Start date Start date
A
AC Question
Hi,
I cannot connect my Huawei P8 to any PC via USB. It worked few times, but then I pressed something in the notifications window (where you can choose what type of USB connection you want) it disappeared and since then I cannot connect it to any PC it is just charging. Also HiSuite does not recgnize it.
Android Version: lollipop 5.0.1
3 years later??? Solution still works!! My laptop stopped recognizing my P20 after an update to either device, and this code fixed it :D It's a little bit of a different menu now but thank you, thank you, thank you!!!!
There is a solution...
In your dialer, type in *#*#2846579#*#* then select in background>usb hisuite and there you have it...
works like magic...
hope it helps.
cheers!
kutty7
