Huawei P9 Android calendar notifications making no sound, ringtone
Siavahda
I have a Huawei P9 and I am constantly missing the notifications for events because, despite having set a ringtone noise (one of my own music files, not one of the phone's default sounds), the notification alert just vibrates once instead and makes no noise. This is especially a problem with early-morning notifs (I have it set to alert me two hours before the event); I have my Do Not Disturb setting until 09:00 am, and don't get the event notifications at all if they are set to go during the do-not-disturb time, even though I have marked the calendar app as a priority one which means it SHOULD go off even during do-not-disturb, as I understand it.
I got it to work by setting the ringtone as the phone's default notification noise (by mistake) - but then I was getting the song playing at every text etc, which is really not workable.
Can anyone help? I want only the calendar notifications to make this sound, and it's driving me crazy that it's just ignoring the settings!
I'm using the default calendar app, btw.
Welcome to Android Central! Is the custom tone saved to the SD card or Internal Storage? Make sure it's the latter, and that you saved it to the Notifications directory.
Aruz530
