So what is the full name for the market search? Launcher pro plus?
Just LauncherPro. Once you pay, you'll get a code to enter which unlocks the "plus" section.
LauncherPro - Android app on AppBrain
I did a search for launcher pro plus and aaw shows up. I am confused, you buy launcher pro then added certain widgets to it?
The dev is supposed to mail you a file that you copy onto your SD card and then install it that way. Until you do that you'll still get the error. If you haven't received that file yet then you need to contact him asap.![]()
I have found that if I delete the contact widget, try to add again, the exact same error message will occur. I believe that the market and/or appbrain is downloading it to the free program. I have to reinstall the apk to get the widget back.
Has anyone figured out where the calendar widget settings are? Mine keeps showing a calendar that I don't need / want displayed right now. I have it hidden in the stock calendar app and another cal widget I have let's me choose which calendars to show. I looked everywhere and can't find the settings for the LPP calendar widget.
the LPP widget can only display from your google calendar or sense calendar for now. youll have to adjust what calendars you want displayed in your google calendar settings
