I hate Lollipop
All the various UI downgrades aside (wasted screen space for less icons available in things like the shortcut tray or the more taps before you can actually type a number in the phone menu), one really annoying issue i'm having is that my system alarms cause my lock screen to effectively have a siezure when it goes off - the top bar blinks wildly, the main lock screen blinks wildy, the home button nav bar at the bottom blinks wildly as if its all fading in and out desynchronised from each other. I can't inertact with it at all and my only option is the force reboot the phone. Generally the whole update is quite terrible and I wish i could easily just go back.
My two finger pull down doesnt work anymore. Also I cant find where to access my alarm. Tapping on the clock in the status bar doesnt work anymore.
I am sure you will get the fix soon. thats the way it works. Well i hope
I also want to throw out my galaxy note 3. Lollipop lost all my s note books. I am ready to revert back to pen and paper and just a phone that receives calls.
I have the same problems that you mentioned. The battery is failing all of the time, where it used to be good for about 2-3 days. Also the wireless seems to drop or not connect at all. All very weird "upgrades". I am not so tech savvy as others, however I came across this post on craigs list. (you can do a search on Craig's List Boston for "lollipop" or just send me a private message) I paid this person $30. I am back to KitKat and couldn't be happier. I was going crazy with Lollipop. She was awesome at downgrading Lollipop to KitKat for me. Hope this helps you guys.
I have the same problems that you mentioned. The battery is failing all of the time, where it used to be good for about 2-3 days. Also the wireless seems to drop or not connect at all. All very weird "upgrades". I am not so tech savvy as others, however I came across this post on craigs list. I paid this person $30. I am back to KitKat and couldn't be happier. I was going crazy with Lollipop. She was awesome at downgrading Lollipop to KitKat for me. Hope this helps you guys.
BNI DIRECT12
