I need help to port ril for any custom rom higher than nougat
Family Team
3
My phone is samsung galaxy note 5 model n920p its a sprint device but i unlocked it to use gsm sim cards and sim cards works only on stock rom when i tried on custom rom pie and copied all the libs files and ril files i always ended up with unknown baseband and in ril log files i get
RILClient: Connect_RILD: Connecting failed. Connection refused(111)
The custom rom i am using is android pie one ui its base is note 8
With help of the dev we made a working kernel with all the ril requirements but the problem now is rom side any help please and thanks in advance
Hi, welcome !
That's something you have to see if the developer of that ROM can fix , we can help with troubleshoot on a stock firmware
I moved this to the Note5 forum for more specific traffic.
okay you said on stock firmware i flashed n920c stock firmware with my stock kernel and i got same results in log files as in custom roms its android 7.0
sorry for late reply yes it worked on stock and it is still working
what i did try is to install another model stock rom on my phone to figure out how ril works i did copy all required lib files and bin files and i couldn't make the sim to get detected or getting a baseband version in about phone
my model is n920p android 7.0
the rom i tried was n920c android 7.0
flashed stock kernel so its a system side only
Hi, yeah on different Rom we can't help like I mentioned earlier you'll need to try talk to the developer of it or play with things until you figure it out .
rlawernce
