i NEED HELP!!!!
logan121691
Active member
Sep 19, 2012
32
my phone is saying that my sd card is blank or that it has unsupported filesystem. when i try to hook it up to my pc it says their is a problem using your sd card for mass storage. i have also tried using a card reader and that didnt work either. everytime i try and format the sd card it doesnt work it just pops up and say that the sd card is currently being checked then it stops trying to format it. i dont really want to lose everything that is on it but if i have to i will.anybody have any ideas???
Any ideas? Yes. Do backups of your SD card more often because it sounds like yours went bad and you are screwed.
When did this problem occur? What has changed?
What format did you use on it?
Backups are key. I have had 2 SD card failures in the last 12 months: 1 after 10 months; the other after only one month.
It happened yesterday right after I dropped my phone. And I just used the phones formatting thing and it didn't work
Sent from my LS670 using Android Central Forums
asnes
