Ice Cream Sandwich to Optimus S?
Re: Ice Cream Sandwhich to Optimus S?
it's really not much to see or do. Just gives you the basic file structure and boots. Touchscreen works better in source builds.
Yep. SDK ports are always iffy, especially on older devices that use legacy touchscreen drivers (LG, I'm looking at you). The source builds can generally be configured to support the older hardware and proprietary bits.
Ok thanks for clarifying. Probably mess around with it anyways
Suprised no-one HAS announced there working on a ICS ROm
anyone have a touchscreen fix for the iceS1 rom or a newer version with more fixes???????
lookig for advice on how to and what apps to use when rooting a LG Optimus on yhe Metro PCS network
if anyone is interested in seeing what ICS looks like on our phones, but don't want to flash this, I found this video.
I messed around and couldnt get any of the ics roms to work (touchscreen, so couldnt check out anything else) on my spare optimus, ill keep playing though, stupid drivers
Reactions: Va1ha11a
just gonna bump this so it doesn't get moved down too far...
yeah right. No one will TRY or ATTEMPT
I'm going to bite my tongue.
Then how did they get the IceS1.zip to work???
It was made for the ZTE Blade.
Yes the IceS1.zip was ported from the ZTE Blade SDK port. But the ZTE Blade ICS ROM you previously linked to is based on AOSP. Maybe it can be re-ported to the Optimus S, but don't get your hopes up.
Reactions: aaronrw
That almost sounds like you know something, Drew !!!
Does Team Hydro have something else up thier sleeves?
Edie Raleigh
