Icons and Sound problems!
guaro81
6
Hello everyone,
I have a new HTC EVO 3D, very happy with my new phone. Recently, I had have two technical issues with my phone.
1.- Every time I connect my cellphone and sync my cellphone with the HTC Sync software, all the shortcuts I created in any screen (if the software is located in the SD card), change from the original shortcut to a generic icon:confused:, leaving me no choice to delete and ad them again. Please, if you have any suggestion I'll really appreciate that. Thanks
2.- If I am listening music using my earphone with mic (I had try different brands, from generic to Blackberry brand) everything is working good, but if I want to hear music using my phone in my car or a boombox, using a auxiliary cable (male to male stereo music cable) or any earphone without mic, my phone behave like crazy, start any song randomly during 1 second and start another song and so on, also redial the last phone number I used and hang up 1 second later, like I said, it is totally crazy :confused:. So, please, if you have any suggestion let me know, I'll be really thankful.
best regards,
For #1, this is a known issue. Simply change "scene" then change back and they will be there. Easier than removing and adding. Not sure on #2. I stream by BT for music in the car, haven't used a male to male yet
sent to you in three dimensions
Reactions: guaro81
Re: Icons and Sound problems!!!
Excellent. Thanks a lot for #1, the problem is solved just like you said. Hopefully for #2 I'll be waiting for another answer to solve the problem.
#1 happens because those programs have been moved to the SD card. Its gonna happen every time you turn your phone off then back on again. I hope they (HTC/sprint) realize this and fix it!
Some brands do perform better at the plug part. But i ended up using the plug less and less. I tried several different plugs for my truck and no matter what brand cord i tried they all eventually failed me.
Jayarealways
