ICS.....05/09/12.....well?
I believe case and filename are correct. As you can see from my attached screenshot, everything appears to be in order? Thanks again for your help guys
That is the internal SD card, move it over to /ext/sdcard2
the only sdcard2 i see is another path from root (no ext\) and it contains the same contents as the screenshot i posted previously.
thx Mr. Smith - any other thoughts? i have no idea what i'm doing wrong, but as you can see, it's getting a little frustrating :-)
can you post a picture of the File Details?
(and, I didn't realize /sdcard/ext_sd/ pointed to /sdcard2 - learned something new today -cool )
/sdcard/ext_sd is a symbolic link to /sdcard2 (its the same directory)
Put it on both to be sure. Do not forget to delete both when you are done....
Sorry about the update thing. I meant the custom Rom obviously
Rezound via Tapatalk 2
It all looks good to me. I am stumped.
How much free space do you have left on the sdcard?
14GB free out of 15GB total...one thing i'm noticing - i do have my SD card encrypted - could that be the cause?
Yeah, HBOOT shouldn't be able to read it since the encryption key is stored in the O/S. If you have another SD, move the RUU over to that (and don't encrypt it)
And there's your smoking gun lol
Want to install ICS leak but I'm always afraid of little quirks with leaks, especially if they lead to the phone running hotter and/or result in decreased battery life.
I'm never much of a sucker for rumors except for software updates such as this..I keep thinking; if only I wait another day, or another week, perhaps VZW will come through.
The answer for you might be unlocking/rooting then. You can stay on the GB firmware and still play with ICS.
wobblefix
