Ics 4.0.1 alpha (aosp)
I am running the 1209-merge Rom and it also broke the wifi tether. When I was on V3 I could use Barnicle without any problems, but it seems to be broken now. I also tried to install the CMsettings.apk, but can't figure out how to change the permissons. Does anyone know how to do this?
-Put the apk on your sdcard -Open root explorer (or your root file manager of choice) and copy the apk on your sdcard, then navigate to the /system/app directory -hit the Mount R/W button -Use root explorer (or your root file manager of choice) and copy the apk to the /system/app directory -Change permissions to: [x] [x] [o] [x] [o] [o] [x] [o] [o] -Reboot
-Or just use adb and do it in 3 commands, refer to Adrynalyns ADB workshop.
This is not from me just sharing
http://rootzwiki.com/topic/9687-rom-aosp-ics-extreme-alphalulz-v2-1118/page__st__990
Reactions: Phattmatt68
I got it! Helps if you know what you are doing! This is the 1st time I've used Root Explorer + I'm kind of a noob! LOL!
Sorry guess i shoulda read the post a bit better. You wanted to know HOW TO not WHAT TO.
For anyone else... to change permissions go to system/app folder with root explorer, mount r/w, long press on the desired app and options will pop up. select permissions and do your thing
No problem, just made me look at what I was doing wrong. Thanks for the help though! :)
Been running for about a week and other than the camcorder and mms it is amazing! Battery life isn't the best but I suppose it's about the same as an unrooted phone. Thanks to everyone involved in putting this out there!
those are what I'm having problems with too, other than that it's great!
This has probably already been posted before but definitely worth re-posting..following these steps one-by-one will fix most common issues.
1. Download the following files in order:
Odin3 v1.85
http://www.google.com/url?sa=t&rct=...IxHp1ISlP2fzGKhtw&sig2=f88p0Arfl2Ng_Brdbix39Q
Official Verizon Gingerbread 2.3.5
Multiupload.com - upload your files to multiple file hosting sites!
PIT for Odin
CWM4 Fixed for CM7 Odin
Teamhacksung's Ice Cream Sandwich Build 2
http://www.enderszone.com/ics/teamhacksung-ota-eng.BUILD2.zip
Teamhacksung's Ice Cream Sandwich Build 5
http://www.mediafire.com/?kp5mhr3a9g4lg1j
Google Apps 7.1
2. Remove battery, plug phone into computer. Press & hold volume down.
Using Odin3, select the Verizon GB file using PDA tab and select the PIT file under PIT.
Press start and wait until completion (PASS! should appear in green).
3. Enter USB storage mode on phone and place the following files in the root directory on your SDCard:
Google Apps 7.1
4. Exit USB mode and remove battery. Run Odin again and select CWM4 Fixed for CM7 Odin using the PDA tab. Press start and wait until completion.
Reinsert battery and press both volume buttons and power simultaneously.
Select Wipe Data/Factory Reset, Clear Cache, Advanced > Wipe Dalvik Cache.
Select Install from zip card and select ICS Build 2. Wait until completion.
5. Press and hold power button and select Reboot > Recovery.
Select Install from zip card and select ICS Build 5. Wait until completion.
You should still remain in the same mode.
Select Install from zip card and select Google Apps 7.1. Wait until completion.
6. Optional Installs:
Multiupload.com - upload your files to multiple file hosting sites! (modified for ICS)
Accurate Battery Modification (shows percentage in icon).
CM9 Glitch 14 Preview 4 Kernel (modified for ICS)
http://androtransfer.com/tk-glitch/...nate/CM9-fascinatemtd-Glitch-V14-Preview4.zip
To install these, simply place the files in the root directory of your SDCard.
Select Install from zip card and select them.
Good luck and enjoy!
Odin3 v1.85
PIT for Odin
Teamhacksung's Ice Cream Sandwich Build 4
http://www.enderszone.com/ics/teamhacksung_fascinatemtd-ota-eng.BUILD4.zip
Google Apps 7
Google Apps 7
Select Install from zip card and select ICS Build 4. Wait until completion.
Select Install from zip card and select Google Apps 7. Wait until completion.
CM9 Glitch 14 Preview 5 Kernel (modified for ICS)
http://androtransfer.com/tk-glitch/...nate/CM9-fascinatemtd-Glitch-V14-Preview5.zip
Isn't TeamHacksungs and this AOSP one completely different?
I am running the AOSP one that was in Post #1 by Dirrk and I wanted to go to TeamHacksungs, BUT from what I gathered, it's a different process to get from this one to Build 4 of TeamHackungs.
am I wrong?
am I wrong?
This is Build 1 I assume which is essentially the same as Teamhacksung's. Although I do recommend flashing Build 2 instead of just going from Build 1 to 4 due to a significant number of changes in the ROM.
I'm on build 6 and my wifi doesn't seem to stay connected. I have the setting for wifi to always stay on, but it won't. Anyone else having this problem or is it just me? Any help is appreciated, thanks.
Sent from my SCH-I500 using Tapatalk
djkodi
